HELP!! Sway bar end link stuck
Old May 15, 2016 | 09:19 PM
Lolik0's Avatar
Hey guys,
I was installing some new coilovers got 3 done without any issues. Front driver side however is giving A TON of issues. After solving most of them I am down to this. My Sway bar end link is just frozen. I removed the nut at the bottom as i did the other side however this was was really stuck on there and when i did the end link did not slide out like the other side its stuck BAD. I tried to remove the upper nut to get the entire thing lose but it wont budge. used PB Weld and a breaker bar and it seems to just start stripping the nut and the socket gets stuck on the nut. I wanted to get some advice here. Next steps im thinking are applying heat, or putting most of it together and getting it towed to a shop which is embarrassing and a sign of failure... i font want that.
Wanted to know if anyone has had this issue, how they solved it. anyone have any advice I dunno i just need some help here. I attached photos.
Attached Thumbnails HELP!! Sway bar end link stuck-img_0674.jpg   HELP!! Sway bar end link stuck-img_0675.jpg
Old May 16, 2016 | 09:58 AM
VenomGT9's Avatar
Bigger breaker bar...add some heat
Old May 16, 2016 | 11:52 AM
gary c's Avatar
Five lb. sledge hammer! Reattach the other side to take pressure off the one you're removing...Gary
Old May 16, 2016 | 12:43 PM
coffeysm's Avatar
Heat - you could destroy the boot though or put the nut back on and whack it a few times with a sledge hammer.
youngdip631
Mar 23, 2016 10:25 PM
flhtvtwin
Steering & Suspension
Mar 16, 2016 06:00 PM
TNRocker
Feb 17, 2016 10:49 PM
