Steering wheel wont center itself
First of all, thank you for your comments.
I recently have the front lower control arms replaced due to damage. the tires were wearing inside very bad. Right after they were replaced, I test drive it and the steering wheel wont come back to center after turning. If I make a 90 degree turn(either side) and leave the wheel, it turns itself all the way to one side instead of recenter. The mechanic said I need to drive some time. It is too tight and will loosen eventually. I know I need an alignment after control arm replacement, but it seems like a bigger problem. I appreciate your advise. |
Jack it up, unhook the tie rod end and turn it by hand to make sure there isnt a lot of resistance at the ball joint or something, could just be alignment though.
Sounds like your so called mechanic grew up in a bone yard, never went to training! Having suspension parts damaged and replaced you shouldn't have left his shop before getting an alignment, that's a no brainer! :OHBOY: Every neighborhood has an "independent brake/alignment shop," all they do is suspensions...find yours!
Gary |
