Racing Brake 13" Rotor Conversion kit
Old May 8, 2020 | 01:30 AM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
Hi all-
I was bored and decided to shop around for big brake kits, and came across this kit from Racing Brake
https://racingbrake.com/2070-k
Seems like a relatively cost effective way to improve braking performance, I haven't heard of this company Racing Brake until now.
Any one on here used them?
Old May 8, 2020 | 10:10 AM
MooseLucifer's Avatar
5 Year Member
blk
This kit does very little other than upset your brake bias and fill out your wheel a bit better. If those are your goals, by all means go for it.
The rotor will give you slightly more heat capacity, but it's still a sliding caliper, and the increased rotor diameter will only amplify the deflection inherent to a sliding caliper. If you want better braking performance/pedal feel, first step is to get fresh fluid in there by bleeding your brakes. While you're at it, swap in a set of stainless braided brake lines and street performance brake pads (Hawk HPS, Sparta 1.0, Stoptech Street etc)
If you want better looking and performing brakes, find yourself a set of OE Brembos.
Ag02M5
Archived Sales
Jan 13, 2010 12:01 PM
highoutput
Sep 3, 2009 02:13 AM
Eric@TCGMiami
Feb 21, 2008 04:28 AM
Paul G
Brakes-Vendor
Feb 8, 2006 10:46 AM
NYCG35
G-SQUAD
Jan 23, 2006 10:42 PM
