Rear Brembo caliper bolt
Old May 15, 2020 | 12:32 AM
Bridgetown's Avatar
New to me G35 in need of some tlc.
Does anybody know if this bolt will work for the rear brembo calipers?
https://www.summitracing.com/parts/arp-665-1003
From what I have searched, the required bolt size is M12-1.75 x 35mm grade 10.9
These bolts don’t seem to be rated at 10.9. It only lists a tourque rating of 98 lb.ft. (Manual specs 58-73 lb. ft.) And a tensile strength of 180,000 psi. In the description they state it is superior to grade 8.
I can pick them up cheaper then the factory one from the dealer.
Old May 15, 2020 | 04:29 PM
MooseLucifer's Avatar
5 Year Member
blk
It'll work, but the black oxide finish will rust, especially when you throw some heat at it. Won't be a problem for a long while as far as strength is concerned, but the rust could cause them to seize up and damage the caliper threads. OE bolts are zinc coated.
Old May 16, 2020 | 12:19 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You can buy the OEM bolts, I think this is the one you're looking for.
https://www.z1motorsports.com/rear-b...79hpn8ufulmru6
That part number might even be in stock at your local Nissan / Infiniti dealership.
clearheart
Apr 17, 2023 11:40 AM
double_jn_it
Mar 10, 2013 09:44 AM
User 92024
DFW G35 Owners Club
Mar 8, 2013 02:21 PM
The Fapsmith
Mar 6, 2013 04:47 PM
mercpc64
Nov 12, 2008 11:14 AM
