G35 H.Tech or 350Z H.Tech
Old Jan 11, 2006 | 02:25 AM
  #31
dream_G35's Avatar
will the z h-techs on a Gcpe hold up fine on stock struts???? or should they be changed.....
Old Jan 11, 2006 | 03:05 AM
  #32
g6g35's Avatar
anybody know the best place to get these?
Old Jan 22, 2006 | 08:16 PM
  #33
ProjectFusion's Avatar
Florida G35 Club, Premier Member
Old Jan 22, 2006 | 10:16 PM
  #34
dream_G35's Avatar
i meant turning and cornering abilities, i was going to go with Z h-tech springs, stock struts and stillen sways to see how it would handle, and if i didnt like it THEN i would get adjustable shocks for $700, but i didnt wanna blow that money if i could save a little.....
Old Jan 22, 2006 | 10:17 PM
  #35
sage's Avatar
If you are referring to the 350z H Tech, the lowest price I've found online is calienteautomotive.com ($125). Please post site if anyone knows of a better/cheaper place...
I am interested to know the best place to get the SPC rear camber arm and tow bolts and the cusco A-arm as well as any comparable alternatives?
Old Jan 23, 2006 | 06:11 PM
  #36
Dan_K's Avatar
Posted this in another thread, but didn't get a response.
What happens when you go with springs that a stiffer in the front, but softer in the rear? I have the G35 H-Tech and after the install, the car seemed to handle better and the ride was a touch stiffer. Could I be crazy?
Old Jan 25, 2006 | 09:20 AM
  #37
z_with_back_seat's Avatar
Originally Posted by tru3630
do you have h-techs for the 350z or g35c
350z H techs
Old Jan 25, 2006 | 09:26 AM
  #38
I got my SPC items on E-Bay. It was one of the store front type sites. It worked out great - Import Auto Performance, for the Cusco A-arms I went throught Bulletproof Automotive. Everything was backordered from Japan at the time so I went with them who beat the price I had.
I have had the combo on for a while now and love the response. I am going to upgrade the shocks this year to D-specs. It should give me the total performance I want and the Drop, even with winter is good.
Old Jan 25, 2006 | 04:04 PM
  #39
Dan_K's Avatar
So you couldn't get the alignment back to spec with the 350z H-Techs?
Old Jan 27, 2006 | 08:48 PM
  #40
I was just outside the limits on the back. The fronts were a little farther. Part of my challenge was the offsets I choose. I did a 18x9 +18 front with 245/40/18 tires and 18x10 +22 rear with 275/40/18 tires. The aggressive offset I feel did not help.
This spring I am going to take out the shocks and replace them with D-specs. I want to go to a track day or two. When I do replace the shocks (BTW they are not worn out) I want go to a recommended tuner alignment shop I did not know about the first time around. I do know I liked the handling better being a little outside the specs. A lot more crisp and responsive without being able to break it loose as much.
Old Jan 28, 2006 | 01:29 AM
  #41
Jamaica2G's Avatar
For all of you saying
"GET THE 350Z H TECHS"
I have one question for you. Are any of you 05 drivers that replaced the sports springs with 327 and 415 F/R spring rates?
I want to know how the handling compares when you get the H-techs that sit 1" lower, increase the front spring rate and decrease the rear spring rate!
I hope what I typed made sense! hahahaha, it has been a long day
Adrian
Old Jan 28, 2006 | 10:54 AM
  #42
2003 6mt
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
