'04 350Z OEM suspension on '05 G35 coupe?
Old Nov 9, 2005 | 01:45 PM
jtkf81's Avatar
Talking '04 350Z OEM suspension on '05 G35 coupe?
hello readers... my friend has '04 350Z and he installed different suspension on his car, so his oem stock suspension is just sitting around. I wondered if I could get a good use of it. I wanted to lower my car in the future, and prefered little more stiffer ride.. if 350Z oem stock suspension fits on my '05 G35, then maybe i can use his, rite? but i am not sure if it does or not... anybody know????
need some help!
Old Nov 9, 2005 | 01:51 PM
CrazyMike's Avatar
Yes, the 350z suspension will fit your coupe. It will lower your coupe by 0.5 inches. Negative camber will be slightly increased but not to the point of needing any additional camber/toe adjustment parts.
Old Nov 10, 2005 | 12:54 AM
dklau33's Avatar
Does your coupe have the sport suspension? And is the 350Z suspension a 04 or an 04.5? Just want to let you know that there are different rear spring rates and different rear shock valving depending on which model. FYI.
G35coupe/350Z 314/342 or 5.6kg/6.1kg
G35 coupe 2005 with sport suspension 314/427 or 5.6kg/7.5kg
350Z coupe 2004.5+ 314/427 or 5.6kg/7.5kg
-Info courtesy of Gsedan35
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
LoSt180
Jul 15, 2015 08:31 AM
