WHAT are the best wheel locks out there?
Old Dec 18, 2005 | 10:54 PM
imRACERX's Avatar
i used to have gorilla locks on my stang but once i lost the key, the tire dealer easily opened the lock. he stuck a socket into it, bending the teeth and easily removed. any other good ones that actually use a key? thanks RX
Old Dec 18, 2005 | 11:24 PM
realgone's Avatar
Widdle ya into kindling
Search the Forum. This has been discussed several times. Most people will recommend the McGard Spline Drive.
Old Dec 18, 2005 | 11:25 PM
Derek S's Avatar
if you ask me gorilla wheel locks are the best
http://www.gorilla-auto.com/
Old Dec 18, 2005 | 11:56 PM
realgone's Avatar
Wish I had seen these before I got the McGard.
http://www.gorilla-auto.com/products...=259&sfID2=261
Old Dec 19, 2005 | 12:30 AM
imRACERX's Avatar
no way, i had the GORILLA and when i lost the key socket, all theyt did is hammer it out. it took them seconds to hammer out the pattern. and even worse, they damaged the lock. all this because i needed new tires and i could not find my gorilla key. I will definately checkj out the other out there. just my opinion.
RX
Old Dec 20, 2005 | 07:31 PM
imRACERX's Avatar
are there any ones that require an alarm or safe lock type key? rx
Old Dec 21, 2005 | 01:03 AM
Triple8Sol's Avatar
...but seriously, if they want them, no wheel lock I've ever seen will stop a thief. I run a combo of 2 different ones, so hopefully itll cut down on the chances.
Old Dec 21, 2005 | 02:27 AM
mrjonang's Avatar
yeah keep one of those in your trunk and when you park just take it out.
Old Dec 21, 2005 | 02:45 AM
luongdmd's Avatar
german sheperds rock....
Old Dec 21, 2005 | 01:39 PM
sen_jen's Avatar
Meatshake Enterprise
a blue nose pit, or a rott.
Old Dec 26, 2005 | 01:39 PM
Q45tech's Avatar
Something people forget is to weigh the lock and get the differential weight vs standard lugnuts......then when machine balancing [radial force] use a temporary stick on weight near the hole where the lock will be installed [mark the hole].
The extra weight even closer to center is enough to throw off balance when installed on car and lock added.
Divide the lugnut radius by the wheel radius to approximate the effect. 28 grams extra weight is like 9-10 gram wheel weight on a 17" rim.
Just like the reason aftermarket rotors need balancing/checking.........every gram is important to get a vibrationfree car.
Old Dec 26, 2005 | 02:05 PM
badtziscool's Avatar
Locks will deter a common thief, but all you have to do is put a steel tube around the lugs, stand on one end, and the studs will snap. Do it 20 times and you have yourself a full set of wheels to sell.
Old Dec 29, 2005 | 01:32 PM
imRACERX's Avatar
The Volks i purchased come with Muteki wheel locks. Any good? RX
Old Dec 29, 2005 | 01:41 PM
sen_jen's Avatar
not at all. very easily to get through. put it this way, any wheel lock can be taken off without the key.
Old Dec 29, 2005 | 01:43 PM
imRACERX's Avatar
so then what should i get?
