G Sedan: Stock back shocks + 350z front?
Stock back shocks + 350z front, is this setup ok? will it be within spec?
i don't know ish about suspension, but my tires are big and if i drop the rear i will rub, but the front gap is too big, bigger than the front.
I have a set of eibach pro-kit springs and i could use those for the front, but i don't know about progressive in front and linear in back...
can any1 please help?
BTW I don't have sports suspension (as far as i know)
thanks guys
thanks guys
i mean the back is pretty much perfect height on my wheels, I will put up some pics soon. Plus I am going to build a custom enclosure and amp rack in the back and it will drop the back even more. (not enough to cause rubbing issues though).
thanks in advance
thanks in advance
I wouldn't do that
Your car just "seems" to be higher at the front, but indeed it is just that the front fender is cut higher. Moroever, if you lower the car like that, you are destroying the 52/48 weight distribution completely..
thanx. i am gonna spring for some TEIN type flex coilovers and an EDFC. that way i can do whatever i want.
will be pricey but nice up here in OR
rezendvous420
May 31, 2020 01:26 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
