Changing break pads..
Old Jan 18, 2006 | 02:48 PM
d4vid's Avatar
when changing breakpads.. is it recommand to open the break fluid cap or no?? can I change pads w/o opening the cap??
Old Jan 18, 2006 | 03:17 PM
SilverII's Avatar
First it is "BRAKE"
Second.... it is not difficult to open the cap...so just open it.
Old Jan 19, 2006 | 06:03 AM
panda007's Avatar
i changed mine without opening the cap... i don't recall having to open the cap for install either. just compress the pistons when installing the brake pads and you should be fine. but during the install, bleeding the brake fluid is recommended.
Old Jan 19, 2006 | 10:41 PM
Aman's Avatar
If you take the resevoir cap off while compressing the caliper piston/s then you wont have to bleed the brakes. Thats how I've always done it on all of my cars.
Old Jan 20, 2006 | 01:11 AM
L454's Avatar
No you do not have to open the cap when you change brake pads. All master cylinders have vented caps anyways. Also I am not so sure leaving the cap off of the master cylinder will bleed your brake lines when you compress the pistons.
Correction: It is a good idea to open the cap when you compress the brake pistons. It allows the air displaced to leave the cylinder as the fluid fills the cylinder.
jbmw002
Drivetrain
Aug 27, 2015 03:01 PM
sahizzle110
Jul 29, 2015 11:36 AM
