Who has the "perfect" rim setup?
Old Jan 20, 2006 | 03:22 AM
shyrock's Avatar
Talking Post your Rim Setup here!
I am looking for pics of the "PERFECT" setup.
I prolly gonna go 19x9.5 in the front w/ 245/35 & 19x10.5 in the rear w/ 275x35. The question is the offset...both front and rear
Please provide pics and YOUR specs:
1. rim size/widths (front and rear) with offsets,
2. tire sizes and brand of your tire (cuz this does make a difference) and
3. if you experience ANY rubbing.
Finally include any revisions you would make if you were to do it over again
Thanks in advance...btw this setup is going on with BREMBOS.
If ur gonna do it...do it right the first time, right?
Old Jan 20, 2006 | 08:27 AM
truplay8's Avatar
THE BATMOBILE
there is no perfect set up..........it depends on how wide and what kind of lip you want
Old Jan 20, 2006 | 01:14 PM
kenchan's Avatar
^^^ +1 and handling/drivability too.
Old Jan 21, 2006 | 04:13 PM
shyrock's Avatar
i'm talking about getting as flush to the fenders as possible w/o any rubbing...that is why i'm asking what people are running on their cars right now and their experience with the setup they have
As well as the size and width of the rim, getting the correct offset is as huge a factor on what will look good on the car. If you get the wrong offset, your nice set of rims will look like garbage on the car.
So...this is why I am asking what the specs are for each individuals rim setup, in the front and back, and to provide pics.
Thanks
Old Jan 22, 2006 | 11:32 PM
Disco_Monkey's Avatar
+28mm front +23mm rear
Old Jan 22, 2006 | 11:45 PM
allforthecash's Avatar
+19 front +23 rear....(i think that's my rear..hehehe)
Old Jan 23, 2006 | 02:15 AM
shyrock's Avatar
For all you VOLKers please say what TYPE you are using as well...high, low, etc.
Old Jan 23, 2006 | 09:50 AM
Chico's Avatar
If I had the coupe I'd go with...
20x8.5 +15 with 245/35/20 front
20x9.5 +20 with 275/30/20 rear
This is as flushed as you can be without any modifications and you can still drop it about 1.25" and be safe.
Old Jan 23, 2006 | 07:42 PM
richboy's Avatar
MORE POWER PLZ!!!
Hey Chico how about 19s? What would be a good size to make it be as flushed too? Im Thinking 19x9.5 +19 and 19x10.5 +23? Is that right?
Old Jan 23, 2006 | 09:31 PM
Chico's Avatar
Yes...they will be flushed with the fenders if you use 255/35 in the front and 285/30 in the rear.
But, your front wheels are a bit agressive in width. Most set ups I've seen on the coupe that work with no problems are with 8.5" or 9" wide in the front which is what I'd recommend. You might want to do a test fit to make sure it clears the suspension.
Old Jan 24, 2006 | 02:35 AM
richboy's Avatar
MORE POWER PLZ!!!
or maybe +21 in fronts... i was going to use 245/35 and 275/35.
Old Jan 24, 2006 | 02:36 AM
richboy's Avatar
MORE POWER PLZ!!!
COuld you tell me your def for flushed? When i say flushed i mines that it matches with the fender and you could stil ldrop it liek 1 inch with no problem
Old Jan 29, 2006 | 03:29 AM
shyrock's Avatar
volks are interesting because they have different "pad setups"(high, low, superhigh, etc) causing the offset to be different for each setup type and different set of rims...hmmmm?!? what to do
Anyone with a Volk GT-V setup with brembos...what offsets are you running?
Old Mar 2, 2006 | 02:49 AM
shyrock's Avatar
Bump:d
Old Mar 2, 2006 | 11:02 AM
robzone's Avatar
anything more more +22 is not aggresive for me.......i had +19 in front with 5mm spacer and +17 in the back back when i had my volks....this will give you the ultimate flushness
