Where to buy TOKICO DSPEC DSP-9
Hey guys, I've been looking for the TOKICO DSPEC DSP-9 shocks. I found a few sites carrying the DSP-7's, but haven't really found one for the DSP-9's. I was wondering if anyone knew a site that would be selling these. Please help!! thxx
Currently doing a promotion:
We got a few D specs DSP 7 and 9's that we'll put out on speical, or $525 shipped including the rear dampening extensions, we will combo them with Tein H techs' or S techs for $650 shipped.
Place your order now!
James@creativeautoworks.com
Originally Posted by amg35
James, what are the rear dampening extensions? Do they affect ride quality? Thanks.
The rear dampening extensions loko basically like brake lines. What they are, are extensions that screw into the top of the rear shock. What it does is, it allows you to adjust the dampening on the rear shocks without removing them for the car. You simply just install them when you install your shocks, and will never again have to remove a tire to change the dampening. You just open your trunk and make the adjustments there, well worth the $30 for them.
How much do you sell the rear extensions for seperately?
Originally Posted by nm3th
How long is this promotion going for? And can the H/S Techs be the ones for 350z?
Common sense tells me the DSP-9 would be around 0.5" shorter than the DSP-7, but I'm just guessing. Couldn't find any info directly from Tokico or in a brief Google search. I'm hoping someone has a definitive answer, or a vendor that carries these products can clarify.
Tokico D-spec twin tube 8 way double adjustable (bump and rebound) gas shocks 2 fitment's are sold DSP-7 for the G35 and DSP-9 for the 350Z.
The only difference between the DSP-7 and 9 is that the rear shocks on the DSP-9 350Z fitment feature's shocks that have shorter shaft's (1" IIRC) The 2 fitment's are both valved the same. These shocks can be set from softer then oem G35 shock to stiffer then the oem 350Z shock, your choice depending on how you set them.
$489
This is from the Suspension sticky on Coilovers, Springs and shock. I guess I could have done the Linky thing but this is more specific.
$489
