Help: Tein Coilovers Rear Dampening Adjustment
Old Feb 14, 2006 | 08:13 PM
Knight's Avatar
I have Tein CS installed on my coupe & I'm trying to access the adjustment **** for the rear dampening. I was told this needed to be access from inside the vehicle.
I have now taken apart the passenger side rear trunk panels, however I do not see access to any dampening adjustment **** or even the top of the shock? Besides metal, the only thing I see is a hard piece of material patched over what appears to be the gas tank area.
Your help would be very much appreciated.
Thanks!
Old Feb 14, 2006 | 08:39 PM
GEE PASTA's Avatar
Florida G35 Club
You can get to the front adjustment easy. The back you will need to pull the shocks and do the adjustment. I would try your adjustments at Front 12 clicks from soft, back 14 clicks from soft.
Old Feb 14, 2006 | 09:02 PM
Knight's Avatar
Yes I did a more thorough search & found a discussion on the D-specs rear adjustment, involving removal of the shock
When installed by a shop I had the adjustment (F/R: 8 clicks from hardest) per Tein recommendation. Now all of a sudden after 6 months (8,000 kms) I noticed a very floaty feeling when driving, especially at higher highway speeds. Actually feels worse than stock setup right now.
As a result I adjusted the fronts to full stiff, however the rears feel very unsafe & I'm assuming this has to do with the soft setting. Cornering is terrible at the moment....
My question is:
Is is relativey simple to unbolt the top of the shock & make the dampening adjustment? I've never done this before, is it a straight unbolt, adjust & bolt back on. For the experienced individuals, what are some careful steps to avoid any damage to myself or the vehicle? Last thing I want to do it damage something...
Thanks!
Old Feb 14, 2006 | 09:14 PM
GEE PASTA's Avatar
Florida G35 Club
Its an easy adjustment. Should not take more than an hour. just raise your car up and pull the shocks one at a time and do your adjustment. Just a quick note: Check your tire pressure and see to it they are perfect. Low pressures can make you think its the shocks
derres
Aug 28, 2015 03:27 PM
itztwinki3
Steering & Suspension
Aug 18, 2015 03:38 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
