Who got squeeky breaks ???
Old Feb 23, 2006 | 03:48 PM
dcutz21's Avatar
Originally Posted by jdj27x
Here is why.... U need to bed in your brakes.
Chances are, that this is why it is happening....
I know you dont have the stoptech's, but try and follow this as close as possible, then report back and let us know if it fixed it.
Make 10 decelerations from 60 to 50 to 5-10 mph. At the end of each brake manuever, immediately accelerate to 60 again for the next deceleeration. Run all 10 manuevers in one cycle.
Afer coolinng run a 2nd cycle of 10 decelerations like the first.
* Plan this procedure so that you dont have to stop with your foot on the pedal while the brakes are hot. Try and use a level surface, and
DO NOT COME TO A COMPLETE STOP AND KEEP YOUR FOOT ON THE PEDAL WITH BRAKES EXTREMELY HOT.... THIS WILL CAUSE ISSUES IF YOU DO.>>>!
Try that and report back soldier.
I just had aftermarket brake pads installed on my front brakes. I know I need to bed them, just don't know where in los angeles I can do it. Any ideas?
Old Feb 23, 2006 | 09:43 PM
jdj27x's Avatar
an empty freeway?
Old Feb 23, 2006 | 11:05 PM
dcutz21's Avatar
I knew that, just thought there would be more of a chance to get stopped by police there than on a regular street.
Old Mar 6, 2006 | 06:40 AM
Godzilla35's Avatar
i have the same problem PLUS the grinding noise... but i saw the video of the Bugatti Veyron.. and it had squeeky breaks too~ hahahha, just fyi..
Old Mar 9, 2006 | 07:21 PM
desperasian's Avatar
ooh! oh! i do i do
Old Mar 14, 2006 | 04:22 PM
driftGT350's Avatar
oh i do too!!!!!
squeaks at LOW speeds like 5-10 mph, i hate it!!!!
Old Mar 16, 2006 | 07:06 PM
1fastsedan's Avatar
your pads are not properly lubricated. i had the same problem untill my friend who is a mercedes teck brought some grease home. what i found is that the squeak wasnt from the pad and rotor but on the pad and caliper, the pad was moving slightly inside the caliper which made it squeak. if that makes sense. so i pulled the front brakes apart and both rotor and pads were scored. i used a small buffing wheel to take this off and then applied grease on the sides of the pad where it slides into the caliper, than i applied grease on the back side of the pad where the piston applies pressure. and i have put 20k on these same pads and have not heard a single sound.
Old Mar 16, 2006 | 08:49 PM
kenchan's Avatar
my brembo's make noise when they are partially heated up. while cool, no noise.
Old Mar 17, 2006 | 02:16 AM
Driver Elite's Avatar
*****UPDATE*****
I went out and did the slam on the breaks thing and it WORKED
My breaks would squeak at low speeds and it was annoying and embarrassing. Now, they make no noise at all and I am proud of myself that I was able to fix yet another problem with my car (I still love my car though).
Anyway, found a backroad, gased it up to 60-70, jumped on the brakes full on until I felt just a bit of abs, and repeated 6 times. Only did one set.
**BEWARE, brake-fade will occur... I have standard 04 brakes, no Brembos. Once the brake fade hits around the third run, the car will take about 5-10feet more to stop which can feel like a helpless feeling, but its ok when you are somewhere where you are not trying to stop before you hit something.
Tested out the brakes against a wall the next day, completely satisfied.
Thanks for the tip. I will pass it on.
Old Mar 17, 2006 | 03:16 AM
aleok's Avatar
Originally Posted by DaVeeD
Ok lets hear it... i know im not the only one with squeeky breaks !!! Stock breaks..Brembo or non-Brembo stock breaks, 05+ breaks, even BBK breaks... i wana know who has squeeky breaks... name what breaks you have... even if you upgraded pads/rotors
04 5AT coupe non-Brembo breaks... squeek at very slow slow speeds and same speed when baking up !!!
I got the exact problem!!
Old Mar 18, 2006 | 05:00 PM
jdj27x's Avatar
Glad to be of help!
Originally Posted by Driver Elite
*****UPDATE*****
Old Mar 21, 2006 | 03:59 AM
fijbert's Avatar
I tried it and I still get that squeek
it's f'in embarassing
and my squeeling is SUPER LOUD
like everyone turns and looks at me and laughs
I just had my brakes changed too!
I'm taking it in and let them do something about it
Old Mar 21, 2006 | 04:39 AM
Canadian's Avatar
Canada, eh?
you paid 60g for your car? typo right??
Old Mar 21, 2006 | 04:43 AM
fijbert's Avatar
nope
100% customs tax...
every car here in lebanon is 2x the price it would be elsewhere
ridiculous.. I know
and u still see Murcilagos on the roads
Old Mar 21, 2006 | 08:21 AM
  #30
fijbert's Avatar
took it in
they fixed it
no clue what they did
I was talkin to a friend... it works great
15mins in and out
