OEM 350Z springs on G35 coupe
Old Mar 3, 2006 | 11:22 AM
LEK's Avatar
LEK
That Guy
Did anyone who has done this experiene camber/toe issues with their g35?!? I think I'm having camber/toe issues.. please advise. Thanks!!
Old Mar 6, 2006 | 08:02 PM
CrazyMike's Avatar
If you get an alignment you shouldn't have any issues with OEM 350z springs. The front toe as well the rear toe & camber had enough adjustment to meet spec.
Old Mar 17, 2006 | 12:59 PM
dj prophecy's Avatar
how about the shock lifespan with the 350 z oem springs? do they shorten vs the stock g35 springs?
Old Mar 17, 2006 | 10:30 PM
haze's Avatar
if the ride height is lowered, i don't see any reason why the shocks will not wear out any faster. if I confused you, i mean i think it will wear out faster.
Old Mar 18, 2006 | 12:46 AM
luongdmd's Avatar
anything that's not OEM will wear it out faster then stock..... unless you change out everything.....
Old Mar 18, 2006 | 12:57 AM
g35cas's Avatar
No problems so far. Have had them on my coupe for about 10k. I don't think the shocks will be affected a whole lot. Your only talking about a 1/2 in. drop. The shocks the coupe are using probably have the same nissan part # as the z anyway. Most of the suspension pieces on the z are the exact same as the coupe.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
