14" Rear Stoptech Rim Rub
Old Mar 13, 2006 | 05:32 PM
myTBG35's Avatar
Hey guys,
My friend and I are installing the 14" F&R stoptech kit on my G35 and was test fitting the rear calipers over my 18" VR LE28N wheels (18x9.5 +30). The caliper clears the spokes fine but the strangest thing goes on when we spin the wheel. The caliper rubs ONLY against a certain part of the wheel on the inside. The rubbing occurs on the top of the caliper above where the bridge and where the pads slide in . It's so strange because it only rubs at this one portion of the wheel where you can see the red caliper paint comeoff. I swapped my other rear wheel on and it rubs too. I'm guessing that somehow my rear wheels are out of round maybe from something I ran over? Does that even make sense?
I put in my front wheels (18x8.5 +28) and they don't rub at all...
Has anyone experienced something like this before or know how this could have happened? Is it possible to run over something that could cause this type of damage and not rip through the tire?
The rub is very very minuscule and is probably less than 1mm. Even so, does the clearance need to be more? Should I take a chance and just file the caliper down where it's rubbing or do I need a new set of rear wheels? Any help would be greatly appreciated.
I can post pics later, don't have a CF reader at the moment.
Alex
Old Mar 13, 2006 | 05:57 PM
StopTech's Avatar
Its not likely that the wheels are out of round, but is it possible that you have stick on wheel weights that are causing the rubbing?
Old Mar 13, 2006 | 06:00 PM
myTBG35's Avatar
Hey Stoptech,
It's not the the wheel weights unfortunately or I'd be happy. It's more towards the center of the inner wheel. The caliper draws a pretty red line where the wheel is seemingly "out of round." I really need to post pics.
Alex
Old Mar 13, 2006 | 07:14 PM
codeflux's Avatar
i take it this is a coupe... on my sedan with 19x9.5 +43 wheels in the rear, the clearance between the 14" 4-piston caliper and the wheel is 1.8 mm. in the front with 19x8.5 +43, the clearance is about 8mm.
you could always grind your wheels down a little with a side-grinder and paint the insides so they don't rust...
Old Mar 14, 2006 | 09:59 AM
myTBG35's Avatar
Thanks for the suggestion. Yes this is on a coupe. I ended up just filling the rear calipers ever so slightly for the clearance.
Here's a picture of the rear caliper and wheel. It's very tight in there, maybe 2mm of clearance.
Old Mar 15, 2006 | 11:54 PM
g35guy86's Avatar
looks nice man
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
jjohns2711
Aug 5, 2015 08:58 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
Soumilg
Jul 18, 2015 12:33 PM
