Anyone else running Brembo blank OEM replacements on they're sedan?
Old Mar 24, 2006 | 11:08 PM
DaveB's Avatar
Tirerack finally got in the stock the OEM replacement Brembo "blanks" for the non-Brembo equipped G35 and 350Z. They were only $57/ea which is $25-60 cheaper per rotor depending on how you order from at Infiniti/Nissan. I had Brembo blanks on my 96 Maxima and they were much better quality that OEM or other cheap aftermarket replacement. Is anyone else running these? I can't seem to find and posts about them.
Old Mar 25, 2006 | 08:47 AM
Q45tech's Avatar
The best easiest test is to accurately weigh new oem vs what you want to substitute.....The heaviest one is 99% the best one.
Accurate measurement to the gram or 1/4 ounce is significant!
Measure the solid edge thickness vs the air space in center vs inner edge thickness.
Lots of little tricks aftermarket does to save cost: less dense less quality cast iron, fewer cooling vents..........looks can be deceiving!
Old Mar 25, 2006 | 11:35 AM
DaveB's Avatar
On my Maxima, the Brembo blanks were about 4 ounces heavier that the OEM pieces. Lots of guys ran them because they were cheaper than OEM and they tended to be far more resistant to warpage. I don't have an OEM G rotor to weigh against my new Brembos. My OEM rotors were absolutely toasted measuring in at .823 with 34K miles and I'm not a hard braker at all. Replacement is recommended at .866.
Old Mar 25, 2006 | 11:54 AM
Q45tech's Avatar
Many times performance [optimized stopping distance] OEM rotors will be made from a softer grade of cast iron to minimize noise when combined with a specific pad composition.
The only way to know is to try Brembo and see what happens ----accurate measurements frequently.
I like to find the optimum compositions to get 40,000 miles on rotors and 2 sets of pads comsummed in that period.
Had lots of practice with the same car [Q45] and 305,000 miles.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
bTanz
Oct 15, 2015 02:31 PM
vstypicals
Jul 20, 2015 10:55 PM
mushu
Jul 15, 2015 03:55 PM
