anyone have the hks ls coilovers?
Old Mar 26, 2006 | 11:21 AM
jeremyblackg35's Avatar
hey looking into gettin either the hks ls or rs coilovers, anyone konw off hand the sign. differences anyone have em on there car is there a big improvmenet / decline in handling and ride..... figured this is the way to go to keep shocks and everything lasting instead of just thorwin gon springs, also gona do a sway bar and camber kit........thanks guys
Old Mar 26, 2006 | 11:43 AM
whiteg35c2's Avatar
All the things you plan to do are good things imho. I've seen the RS change the G35 from a luxury boat to a well mannered high-speed turn eater =). By numbers, the LS+ has a stronger spring rate and would give stiffer characteristics so it depends on what you are looking for. Sway bars should help with whatever residual body roll there is and camber will save your tires.
If you need any tips on installation of the HKS coils I've helped install a set so I can give you a few pointers, just shoot me a PM!
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
