Best settings for these sway bars.
Old Apr 24, 2006 | 10:39 PM
GThIrtYFiZle's Avatar
What settings should I put my sway bars on having bigger rims with 245 in the front and 275 in the back. Should I put them on soft/med or med/med.
By the way, I have the stillens and I have the polyurethane bushings on them.
Old Apr 24, 2006 | 11:35 PM
Andy2434's Avatar
If you are doing the install yourself, I would start with soft/med and test it out and experiment a bit. If you are paying someone else to install the sway bars, I would suggest going with med/med.
Old Apr 25, 2006 | 01:51 PM
Diesel1's Avatar
Moderator
I have medium medium on mine and love it!!!!
Old Apr 25, 2006 | 03:14 PM
Rookie84's Avatar
Depends on what you like in terms of balance. Stiffer rear = more oversteer.
Old Apr 25, 2006 | 03:26 PM
keib's Avatar
Just got mine in, but waiting for bushings. Someone else is doing the install. Based upon the many threads on the issue...leaning toward med/med. But wondering if it's a PIA to go back and forth to sample the other settings. Running stock suspension with 245/275.
Old Apr 25, 2006 | 04:22 PM
Ok, so the follow up on my post. First of all, I was not able to use to polyurethane bushings for the front. For the back I did. I dont know if this makes a difference but whatever I think its ok. Asd far as the ride goes. I put my settings on med/med and the car handles unbelievably better. It also seems that I am able to reach higher speeds quicker, but I think this is because its harder to feel how fast you are going since the car is so firm. Basically I love it. I have not yet ried it to its full extent, but I have taken some turns at higher speeds that I was not able to do earlier and I can definitely feel the difference.
Old Apr 25, 2006 | 07:44 PM
Andy2434's Avatar
Right on! Glad you are enjoying your new sway bars. My Stillen bars are set at med/med. After I lower and install a wheel/tire combo, I'll be curious to see if I'll be changing the bar settings.
Old Apr 25, 2006 | 07:47 PM
Andy2434's Avatar
If you have access to a lift . . . Changing the sway bar settings is a breeze. Without it, it's a PIA. I really do not like crawling around under car if I don't have to. Med/med is working out excellent for me at the moment. I am running stock suspension and OEM 19's.
Old Apr 26, 2006 | 03:05 PM
G-Tofu's Avatar
hey guys....where do you buy the Polyurethane busing?
Old Apr 26, 2006 | 06:10 PM
keib's Avatar
Thanks Andy...
I see you're running 255/285 on the Challenges. Rears 9.5? If so, any issues? Rub?..stretched look?
Doh!...just noticed the "ordered" in your sig.
keib's Avatar
Pulled this from a post in the suspension section:
Quote:
Originally Posted by headpaneer
I know some people with the Stillen bars have purchased Prothane bushings to replace the stockers. Does anyone have the part number(s)?
SUSPENSION RESTORATION PARTS COMPANY
319-B MOTOR CITY COURT
MODESTO, CALIFORNIA 95356
(209) 578-5101 Tech questions & orders
1(800)-291-5340 ORDERS ONLY
Prothane brand
Front bushings Part # 14-1115 $21.00
Rear bushings Part# 14-1116 $21.00
California residents please add 7.375% sales tax
Old Apr 26, 2006 | 06:28 PM
mephistomyhero's Avatar
If you were to buy other Sways (Nismo, Eibach, etc.), would you still use the new Polyurathane bushings?
Old Apr 27, 2006 | 08:57 AM
keib's Avatar
https://g35driver.com/forums/brakes-suspension/55776-sway-bar-summary.html
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
SIKKI
Steering & Suspension
Sep 16, 2015 01:14 AM
migurus
Sep 5, 2015 09:39 PM
Machine Head
Sep 4, 2015 07:22 PM
TheBay
Sep 3, 2015 03:27 PM
