Emergency! Wheel Problems!
Old Apr 25, 2006 | 08:18 PM
wkclem's Avatar
I recently purchased a set of Racing Hart 721's from WheelAutoHaus.. No issues there.
Upon installing the fronts, I found this nubby bolt looking thing between two of the mounting lugs. The wheels dont clear it!! Granted, there are cut-outs between the lug holes on the wheel and it looks like it should just slip into one of those.. but it doesnt. Any ideas????
Now I've got two pretty new wheels (rears), one dirty stocker, and the front right of my car sitting on a jack. Any help would be much appreciated.
Old Apr 25, 2006 | 08:33 PM
nouse4aname's Avatar
remove the bolt! its useless, until you need to take your rotors off.
Old Apr 25, 2006 | 08:46 PM
SFLG35's Avatar
FGC President
its even useless then
that bolt is only there to keep idiots from putting the rear tires on the front when rotating the tires
take it off and dont even give it a second thought
Old Apr 25, 2006 | 08:47 PM
GLuXuRy's Avatar
haha... how can he take it off ? ive seen it once or twice... but never really examined it
Old Apr 25, 2006 | 08:50 PM
abcdefGGGGGG's Avatar
yea take that off. had to take it to my autoshop to remove it becaus ei had no tools on me.
Old Apr 25, 2006 | 08:52 PM
wkclem's Avatar
Problem is, it looks more like a welded on shaft with a bolt on the very end. I dont think the wheel will clear the shaft, even with the bolt off. Or does the whole piece come off once the bolt is removed?
Old Apr 25, 2006 | 08:55 PM
SFLG35's Avatar
FGC President
its just a screw turn it counter clockwise
aka lefty loosey righty tighty
Old Apr 25, 2006 | 08:56 PM
SFLG35's Avatar
FGC President
it comes right off its not welded
Old Apr 25, 2006 | 08:57 PM
just grab a wrench and take it off, its not stuck on there like you think. you probably wont use that piece again.
Old Apr 25, 2006 | 08:59 PM
jwebb82rez's Avatar
Get a socket that fits the nut on the end, take it off, the whole thing will just fall off when you start to turn the socket. You will see how pointless it actually is when you take it off. It is just so that people that don't know these cars won't put the rear wheels on the front when rotating them. If you look at the rear caliper of your car they are not there, nor is there a slot in the rear wheels that would fit over the stupid thing on the front calipers. The front stock wheels have notches to slide over the "pointless stupid thingy".
Old Apr 25, 2006 | 09:00 PM
wkclem's Avatar
Thanks all!
Unfortunately its too damned dark outside to be installing wheels. I'll have to wait until morning.....
Old Apr 25, 2006 | 09:02 PM
GLuXuRy's Avatar
just set fire to your driveway... youll have plenty of light... id be all over this if i had wheels just sitting there
Andy2434's Avatar
Awesome! Thanks for the heads up, people.
Old Apr 25, 2006 | 09:04 PM
wkclem's Avatar
LOL
I dont think the condo association would appreciate that much. Besides, the mini-vans that typically bang my doors up around this hour would likely hit me instead. Hmmm, on second thought that may not be a bad thing.
Old Apr 25, 2006 | 09:09 PM
wkclem's Avatar
While I got so many of you active on this thread.. What brand should I look to for quality security lug nuts?
The RH wheels were provided with a smaller (skinnier) lug nut that requires a similar extension to the tire iron, but this doesnt seem very secure..
