DBA Brake Rotors (brembo replacement) + Ferodo Brake Pads (street/race)
Old Oct 23, 2007 | 11:12 PM
RAVSPEC's Avatar
DBA 5000 Series (Front only for Brembo Caliper)
Gold Hat Slotted+Drilled - $825 Shipped Per Pair
Black Hat Slotted only - $799 Shipped Per Pair
** Custom Color (Blue or Red), PM us ! **
DBA 4000 Series
Brembo Caliper 350Z Only
(Gold Center) Slotted and Drilled Front - $385 per Pair (Front or Rear) Shipped
(Black Center) Slotted only - $362 Shipped Per Pair (Front or Rear)
Non-brembo 350Z (Standard/Touring Model) Only (Specify 03~05 or 05~07 Model)
(Gold Center) Slotted and Drilled Front - $323 per Pair (Front or Rear) Shipped
(Black Center) Slotted only - $351 Shipped Per Pair (Front or Rear)
DBA Street Series
(Gold Center) Slotted and Drilled Front - $239 per Pair (Front or Rear) Shipped
(Black Center) Slotted only - $217 Shipped Per Pair (Front or Rear)
FERODO Brake Pad (DS2500 Street and DS3000 Racing)
Ferodo DS2500 (Street) Performance Brake Pads
- Nissan 350Z/ G35 (Brembo) Front - $125 Shipped
- Nissan 350Z/ G35 (Bremb0) Rear - $90 Shipped
- Nissan 370Z/G37 (Akebono) Front - $195 Shipped
- Nissan 370Z/G37 (Akebono) Rear - $155 Shipped
Ferodo DS3000 (Race) Performance Brake Pads
- Nissan 350Z/G35 (Brembo) Front - $179 Shipped
- Nissan 350Z/G35 (Brembo) Rear - $139 Shipped
- Nissan 370Z/G37 (Akebono) Front - $275 Shipped
- Nissan 370Z/G37 (Akebono) Rear - $223 Shipped
Technafit Stainless Steel Brake Lines - $159 Shipped
Available Application (Non-brembo or Brembo) * Please Specifiy When Order
DS2500 (Street) Brake Package For G35 / 350Z (Brembo) - $385 Shipped
Package Included: Front and Rear DS2500 Ferodo Brake Pads, Technafit Stainless Steel Coated Brake Lines (DOT Approved), 2 x Motul BF600 Brake Fluid
DS3000 (Performance Race) Brake Package For G35 / 350Z (Brembo) - $485 shipped
Package Included: Front and Rear DS3000 Ferodo Brake Pads, Technafit Stainless Steel Coated Brake Lines (DOT Approved), 2 x Motul BF600 Brake Fluid
DS2500 - Highway Specification
This race developed pad has all the qualities required for a world beating high performance street pad. Its consistent coefficient of friction (0.47) at any temperature low or high gives very predictable bracking and great pedal modulation. This new generation of friction material is very low in compressibility ensuring a firm pedal feel, while still providing great life for both rotor and pad. Combined with the low dusting of the wheels and low noise this product is "the" brake pad for the driver who demands the ultimate in braking performance.
DS3000 - Track / Race Only
[i]DS3000 has set the braking standard since its introduction in 1998. DS3000 has contributed to countless wins and podium positions in many Touring car and GT championships around the world.
DS3000 has
- reduced bedding in time (approx. 50% quicker than other materials)
- extremely high friction level at any temperature or speed
- higher initial bite
- predictability, in all conditions, when bracking into the corner because of the flat
friction curve
- less off brake between the brake pedal and throttle
When using the material with light inertia racing cars, as a general rule it is necessary to apply less brake pedal pressure than you would normally expect. This will avoid overbraking and generation of excessive heat in the braking system and disc. DS3000 is not suitable for road use.
Thank you.
Old Dec 1, 2007 | 12:44 AM
RAVSPEC's Avatar
weekend bump ...
Old Dec 14, 2007 | 10:26 PM
RAVSPEC's Avatar
^Weekend Bump!
Old Jan 26, 2008 | 10:25 AM
RAVSPEC's Avatar
weekend bump !
Old Feb 13, 2008 | 01:48 PM
RAVSPEC's Avatar
Bump, first post updated!
Old Apr 8, 2008 | 01:26 AM
johnnyd's Avatar
DBA 5000 Series (Gold Center) Slotted and Drilled Front Rotors and DBA 4000 Series Slotted and Drilled Rear Rotors For 350Z (Brembo). can i get teh 5000 series in a blue hat?
Old Apr 8, 2008 | 11:19 AM
RAVSPEC's Avatar
Blue, would have to be special ordered.
(also, the special listed is on in stock items only! )
Thank you.
Old Apr 8, 2008 | 05:31 PM
johnnyd's Avatar
okay. should be buying a set from you by friday.
johnny.
Old Apr 8, 2008 | 06:38 PM
RAVSPEC's Avatar
Sure, let us know. Thanks.
Old May 23, 2008 | 12:13 PM
RAVSPEC's Avatar
Bump for these in stock items!
Old Jun 13, 2008 | 07:16 PM
RAVSPEC's Avatar
Fathers day bump^
Old Jun 25, 2008 | 10:43 AM
kamikazeiG35's Avatar
Pricing clarification please...
PM'd you.
Old Jun 26, 2008 | 12:09 AM
RAVSPEC's Avatar
replied
Old Aug 8, 2008 | 12:52 PM
RAVSPEC's Avatar
Weekend bump!
Old Aug 15, 2008 | 03:30 PM
RAVSPEC's Avatar
Weekend bump
