Brake combos from$239-Slotted Rotors$225-Free Brake Fluid With Hawk Pads
Old Apr 15, 2008 | 06:01 PM
gruppe-s's Avatar
Former Sponsor
All brake components on sale! Dont miss out on these awesome prices. Brake combos in stock from Mild Street to Full Track. Looking for full track upgrades Pm us for your needs.
Brake Upgrades
Stage 1 Brake Package
Street System
- Hawk HPS F&R Brake Pads
- Gruppe-S Brake Lines
- 1L ATE Brake Fluid
03-04 G35 $239 Shipped
05-07 G35 $259 Shipped
02-04 G35 Brembo $325 Shipped
Stage 2 Brake Package
Performance Street System
- SP 1pc F&R Slotted Rotors
03-04 G35 $550 Shipped
05-07 G35 $550 Shipped
02-04 G35 Brembo (Front Rotors Only) $549 Shipped
Looking For Individual Brake Components?
All items In Stock Ready To Ship
SP Slotted Rotors
With SP Performance Slotted rotors, you will feel the difference. Its series of slots wipe the surface of the rotor forcing the gases to expel through the slots. The slots also greatly improve wet weather braking by preventing hydroplaning between the pad and rotor. The slots on SP Performance rotors are machined to the minimum thickness.
03-04 G35 F&R
$335 Shipped
05-07 G35 F&R
$335 Shipped
02-04 G35 Brembos Fronts Only
$225 Shipped
Hawk HPS Brake Pads
HPS (High Performance Street) Compound - provides advanced braking characteristics to enhance your driving experience. High performance street pads that are race worthy. All Hawk pads are compatible with factory brakes & A.B.S. systems.
03-04 G35 F&R
$160 Shipped
Free ATE Super Blue Brake Fluid
05-07 G35 F&R
$160 Shipped
02-04 G35 Brembo F&R
$195 Shipped
Gruppe-S Steel Braided Brake Lines
Gruppe-S Stainless Steel Braided Teflon Hoses could very well be the easiest and least expensive way to upgrade your braking system. In any braking system there is flex ? in the pedal, in the caliper, but most of the flex is in the hose. Every time you step on your brake pedal, up to 1500 pounds of pressure moves brake fluid from the master cylinder to the caliper. Most of the way, the brake fluid moves through rigid steel lines. Unfortunately, these steel lines cannot complete the journey all the way to the caliper because movement in the line is necessary to connect a non-moving part (the chassis) to a moving part (the brake assembly as attached to the wheel). These connecting hoses are made from rubber and nylon. Even with the nylon braiding inside the hose, when that much pressure hits it, it will expand. This expansion, or flex, weakens the braking system as it allows for loss of energy meant for the calipers. With Gruppe-S Stainless Steel Braided Teflon brake lines, this flex is reduced dramatically ? this means quicker pedal response and shorter braking distances.
03-07 G35Z
$99 Shipped
03-04 G35 Brembo
$130 Shipped
ATE Brake Fluid
ATE Super Blue brake fluid is designed for coping with the extreme demands posed by motor racing, and makes an excellent choice even for street-driven or autocrossed vehicles. Thanks to its outstanding wet boiling point, it has the highest of safety reserves. The dry boiling point is 535F (280C). Wet boiling point is 392F (200C). Exceeds all DOT4 standards, though is not DOT compliant due to the color (blue instead of yellow/gold).
1 Liter Bottle
$20 Shipped
GREX Brake Systems
Backed by extensive research and development, GReddy Brake Systems are designed as full competition-spec. brake kits suitable for street use. Each application-specific GReddy Brake System kit will work with a wide variety of wheels. Lightweight 4 and 6 piston aluminum calipers are designed to be as compact as possible and are stylishly protected by our classic GREX gold hard anodized finish. Large lightweight, motorsport style, two-piece rotors use an anodized, duralumin bell housing to prevent rusting and scratching. The finest quality Earl’s Teflon lined stainless steel braided brake hoses are also included for maximum performance and reliability.
8 Piston 380mm Gold (Front)
$4199 Shipped
6 Piston 355mm Gold (Front)
$2750 Shipped
4 Piston 330mm Gold (Rear)
$2099 Shipped
Greddy 6 Piston Front/ 4 Piston Rear
$4699 Shipped
Stoptech
Big Brake Kits give your vehicle that Supercar look and feel, and exceed stock performance in two areas. First, larger rotors increase heat capacity. Second, stiffer calipers and stainless steel lines reduce system compliance.
The key, however, is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio. If the brake upgrade you select adds too much front torque (as many do), you reduce your car's ability to utilize the tractive capacity of all of the tires to the maximum practical extent (even on ABS equipped cars) and you therefore create performance sacrifices. In addition, too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate, which limits a driver's control of brake input on the race track.
Advantages of StopTech over other brake upgrades:
Shorter Stopping Distances
Better Brake Modulation
Firmer Brake Pedal
Less Brake Fade
Feature Benefit Summary:
Balanced Brake Upgrades™ with optimum brake bias offer the shortest stopping distance with the best pedal feel
Our patented AeroRotors® with the best airflow available result in better cooling, less fade and longer rotor and pad life
The stiffest aftermarket calipers with patented bridge result in better clamping under hard braking and less pad taper
Track testing of new applications ensures optimum performance
FRONT: 332 x 32 mm Rotor/ 4 Piston Caliper
REAR: 328 x 28 mm Rotor/ 2 Piston Caliper
PM For Price
FRONT: 355 x 32 mm Rotor/ 4 Piston Caliper
PM For Price
REAR: 355 x 32 mm Rotor/ 4 Piston Caliper
PM For Price
FRONT: 355 x 32 mm Rotor/ 6 Piston Caliper
PM For Price
FRONT: 355 x 35 mm Rotor/ 4 Piston Caliper
PM For Price
Brembo Grand Turismo
The Gran Turismo system's level of technology and performance is unrivaled by any other product on the market. Each system is designed vehicle specific for maximum performane and "Optimum Brake Balance".
Gran Turismo Systems are comprised of lightweight 4, 6 or 8 piston calipers and 1 piece or 2 piece "floating" vented rotors up to 15" in diameter. Calipers are available in red, silver or black and discs are available in cross drilled or slotted. Increased brake torque and thermal capacity, dramatically improves the vehicles performance.
This powerful combination offers the extreme in Brembo's leading edge technology for high performance street and track use applications.
Brembo brake systems are fully compatible with your vehicles ABS and traction control systems. Systems are pre-assembled and include all necessary hardware for ease of installation.
332x32 2-Piece Front Kit
$2699 Shipped
355x32 2-Piece Front Kit
$2999 Shipped
Old Apr 15, 2008 | 10:49 PM
Slick 6MT's Avatar
How do these SP Performance Slotted rotors compare with the OE replacement slotted Stoptechs?
Old Apr 16, 2008 | 04:57 PM
gruppe-s's Avatar
Former Sponsor
They are actually good rotors. They are made in the USA so they are great quality build.
Gruppe-S
Old Apr 21, 2008 | 08:30 PM
gruppe-s's Avatar
Former Sponsor
Old Apr 22, 2008 | 04:03 PM
gruppe-s's Avatar
Former Sponsor
Old Apr 23, 2008 | 06:49 PM
gruppe-s's Avatar
Former Sponsor
Old Apr 24, 2008 | 05:24 PM
gruppe-s's Avatar
Former Sponsor
Old Apr 25, 2008 | 06:49 PM
gruppe-s's Avatar
Former Sponsor
Old Apr 28, 2008 | 07:04 PM
gruppe-s's Avatar
Former Sponsor
Old Apr 29, 2008 | 06:08 PM
gruppe-s's Avatar
Former Sponsor
Old Apr 30, 2008 | 04:53 PM
gruppe-s's Avatar
Former Sponsor
Old May 1, 2008 | 03:44 PM
gruppe-s's Avatar
Former Sponsor
Old May 2, 2008 | 09:54 AM
Steel Blue's Avatar
What size are the slotted SP rotors? Are they a direct replacement to the NON-Brembo rotors?
Old May 2, 2008 | 03:34 PM
gruppe-s's Avatar
Former Sponsor
Yes the Sp rotors are direct replacement. Same as stock.
GRUPPE-S
Old May 5, 2008 | 07:05 PM
gruppe-s's Avatar
Former Sponsor
