DBA,Brembo,EBC,Akebono's Hawk,Power Slot,Motul- In Stock
Old Dec 6, 2008 | 06:25 PM
Iperformancellc's Avatar
Smile DBA,Brembo,EBC,Akebono's Hawk,Power Slot,Motul- In Stock
*****BRAKE THREAD******
PM for all "Qoutes & Combos"
*Pads*
EBC
EBC Greenstuff Pads
MODEL#:
DP21636 Front Pads Nissan 350Z - 3.5 (2002 - 2005)
DP21666 Rear Pads Nissan 350Z - 3.5 (2002 - 2005)
DP21644 Front Pads Nissan 350Z - 3.5 (Brembo) (2002 - 2007)
DP21537 Rear Pads Nissan 350Z - 3.5 (Brembo) (2002 - 2007)
EBC Yellowstuff Pads
EBC Yellowstuff (1793 Formula) street, race and track pad delivers world class braking designed for High Horsepower imports and Muscle cars where maximum stopping is prime requirement. Its dust rating is similar to OEM parts.
MODEL#:
DP41636R Front Pads Nissan 350Z - 3.5 (2002 - 2005)
DP41666R Rear Pads Nissan 350Z - 3.5 (2002 - 2005)
DP41644R Front Pads Nissan 350Z - 3.5 (Brembo) (2002 - 2007)
DP41537R Rear Pads Nissan 350Z - 3.5 (Brembo) (2002 - 2007)
EBC Redstuff Pads
EBC Brakes have rebuilt their earlier Redstuff compound with Ceramic particles and other special ingredients to deliver perfection in stopping power for even the fastest street use. Ideal for High Horsepower imports, muscle cars and especially suitable for European high end cars. EBC Redstuff Ceramic pads cut the dust emitted by OEM pads in half, reduce rotor wear and last longer while delivering ultimate brake performance.
MODEL#:
DP31636C Front Pads Nissan 350Z - 3.5 (2002 - 2005)
DP31666C Rear Pads Nissan 350Z - 3.5 (2002 - 2005)
DP31644C Front Pads Nissan 350Z - 3.5 (Brembo) (2002 - 2007)
DP31537C Rear Pads Nissan 350Z - 3.5 (Brembo) (2002 - 2007)
EBC Ultimax Brake Pads
*OEM OR BETTER PADS*
MODEL#:
UD815 Front Pads Nissan 350Z - 3.5 (2002 - 2005)
UD905 Rear Pads Nissan 350Z - 3.5 (2002 - 2005)
UD960 Front Pads Nissan 350Z - 3.5 (Brembo) (2002 - 2007)
UD961 Rear Pads Nissan 350Z - 3.5 (Brembo) (2002 - 2007)
*Fluids*
Brembo Sport.EVO 500++ Brake Fluid: $18
Brembo Sport.EVO 500++ is a premium brake fluid that has been specially formulated to meet any ENTHUSIAST needs. For maximum safety and performance Brembo recommends that the fluid should be changed every year.
MODEL#:
BRE04816412EVO Nissan 350Z - 3.5 (2002 - 2005)
BRE04816412EVO Nissan 350Z - 3.5 (Brembo) (2002 - 2007)
Brembo LCF 600 Plus Brake Fluid: $35
Brembo LCF 600 Plus Brake Fluid has been formulated to provide the highest performance in all racing conditions and has an independently proven low compressibility at high temperatures. Exceeding the requirements of U.S. FMVSS 116 DOT4 specifications, the Brembo fluid also resists boiling at higher temperatures (both wet and dry) over other race fluids. Not suitable for brake systems containing magnesium parts.
MODEL#:
BRE04816411LCF Nissan 350Z - 3.5 (2002 - 2005)
BRE04816411LCF Nissan 350Z - 3.5 (Brembo) (2002 - 2007)
*Rotors*
DBA ~ Disk Brake Australia
DBA 4000 Series
DBA 4000 Series Direct Replacement Rotor is a premium street performance rotor with aggressive appearance for the spirited street driver or performance modified street vehicle, the 4000 series XS premium cross- drilled and slotted design is the best option. Features
* Patented "Kangaroo Paw" ventilation design
* Thermal Stability Profiling
* Minimal bedding-in of rotor
* Premium non-directional cross-drilled and slotted design (XS)
* Thermo-Graphic paint markings for temperature monitoring
* Rotor protection paint on hub/hat surface
* Rapidly expels friction gases
DBA 4000 Cross Drilled & Slotted Series
MODEL#:
DBA 4600XS Front Nissan 350Z - 3.5L V6 - Brembo Pkg. (10/2005-2007)
DBA Rear Nissan 350Z - 3.5L V6 - Brembo Pkg. (10/2005-2007)
DBA 42308XS Front Nissan 350Z - 3.5L V6 Std./Performance/Enthusiast/Touring models (10/2005-2007)
DBA 42309XS Rear Nissan 350Z - 3.5L V6 Std./Performance/Enthusiast/Touring models (10/2005-2007)
DBA 4954XS Front Nissan 350Z - Std./Performance/Enthusiast/Touring models (2003-2005)
DBA 4574XS Rear Nissan 350Z - Std./Performance/Enthusiast/Touring models (2003-2005)
DBA 4600XS Front Nissan 350Z - Track & 35th Ann. Edition - w/ 4 piston front caliper (2003-2005)
DBA 4601XS Rear Nissan 350Z - Track & 35th Ann. Edition - w/ 4 piston front caliper (2003-2005)
DBA 4000 Slotted Series
MODEL#:
DBA 42308SL-SR Front Nissan 350Z - 3.5L V6 Std./Performance/Enthusiast/Touring models (10/2005-2007)
DBA 42309SL-SR Rear Nissan 350Z - 3.5L V6 Std./Performance/Enthusiast/Touring models (10/2005-2007)
DBA 4954SL-SR Front Nissan 350Z - Std./Performance/Enthusiast/Touring models (2003-2005)
DBA 4574SL-SR Rear Nissan 350Z - Std./Performance/Enthusiast/Touring models (2003-2005)
DBA 4600SL-SR Front Nissan 350Z - Track & 35th Ann. Edition - w/ 4 piston front caliper (2003-2005)
DBA 4601SL-SR Rear Nissan 350Z - Track & 35th Ann. Edition - w/ 4 piston front caliper (2003-2005)
DBA 5000 Series Direct Replacement rotors
DBA 5000 Series Direct Replacement rotor is for the serious driver, these 2-piece ultra -high performance rotors feature aerospace grade materials for added thermal (heat) protection to your vehicles wheel bearings. The aircraft-grade aluminium centre/hat/ bell provides greater resistance to distortion as it allows the disc to expand uniformly. Features
* Alumalite centre/hat/bell made form light weight 6061-t6 aircraft aluminium material (re-useable)
* Replacement disc rotors available (without aluminium centre)
* Directional slotted design (left-hand and right-hand disc rotors)
* NAS (National Aerospace Standard) bolts and lock nuts
* Thermal Stability Profiling (TSP)
* Thermo-graphic paint markings
* Also available in standard finish (non-slotted) for production car racing
DBA 5000 Series Sloted and Cross Drilled Direct Replacement rotor
MODEL#:
DBA 5600BLUXS Front Rotor (Blue Hat) - Nissan 350Z - 3.5L V6 - Brembo Pkg. (10/2005-2007)
DBA 5600GLDXS Front Rotor (Gold Hat) - Nissan 350Z - 3.5L V6 - Brembo Pkg. (10/2005-2007)
DBA 5600REDXS Front Rotor (Red Hat) - Nissan 350Z - 3.5L V6 - Brembo Pkg. (10/2005-2007)
DBA 5600BLUXS Front Rotor (Blue Hat) - Nissan 350Z - Track & 35th Ann. Edition - w/ 4 piston front caliper (2003-2005)
DBA 5600GLDXS Front Rotor (Gold Hat) - Nissan 350Z - Track & 35th Ann. Edition - w/ 4 piston front caliper (2003-2005)
DBA 5600REDXS Front Rotor (Red Hat) - Nissan 350Z - Track & 35th Ann. Edition - w/ 4 piston front caliper (2003-2005)
DBA 5000 Series Sloted Rotor
MODEL#:
DBA 5600BLKSL-SR Front Rotor (Black Hat) - Nissan 350Z - 3.5L V6 - Brembo Pkg. (10/2005-2007)
DBA 5600BLUSL-SR Front Rotor (Blue Hat) - Nissan 350Z - 3.5L V6 - Brembo Pkg. (10/2005-2007)
DBA 5600GLDSL-SR Front Rotor (Gold Hat) - Nissan 350Z - 3.5L V6 - Brembo Pkg. (10/2005-2007)
DBA 5600REDSL-SR Front Rotor (Red Hat) - Nissan 350Z - 3.5L V6 - Brembo Pkg. (10/2005-2007)
DBA 5600BLKSL-SR Front Rotor (Black Hat) - Nissan 350Z - Track & 35th Ann. Edition - w/ 4 piston front caliper (2003-2005)
DBA 5600BLUSL-SR Front Rotor (Blue Hat) - Nissan 350Z - Track & 35th Ann. Edition - w/ 4 piston front caliper (2003-2005)
DBA 5600GLDSL-SR Front Rotor (Gold Hat) - Nissan 350Z - Track & 35th Ann. Edition - w/ 4 piston front caliper (2003-2005)
DBA 5600REDSL-SR Front Rotor (Red Hat) - Nissan 350Z - Track & 35th Ann. Edition - w/ 4 piston front caliper (2003-2005)
Old Dec 6, 2008 | 06:27 PM
DBA 5000 Series Drilled/Slotted Replacement Rotor Set
MODEL#:
DBA 5600.1XS Front Rotor Nissan 350Z - 3.5L V6 - Brembo Pkg. (10/2005-2007)
DBA 5600.1XS Front Rotor Nissan 350Z - Track & 35th Ann. Edition - w/ 4 piston front caliper (2003-2005)
DBA 5000 Series Slotted Replacement Rotor Set
MODEL#:
DBA 5600.1SL-SR Front Nissan 350Z - 3.5L V6 - Brembo Pkg. (10/2005-2007)
DBA 5600.1SL-SR Front Nissan 350Z - Track & 35th Ann. Edition - w/ 4 piston front caliper (2003-2005)
DBA Gold Street Series (Drilled & Slotted) Rotor Set
MODEL#:
DBA 2308X Front Nissan 350Z - 3.5L V6 Std./Performance/Enthusiast/Touring models (10/2005-2007)
DBA 2309X Rear Nissan 350Z - 3.5L V6 Std./Performance/Enthusiast/Touring models (10/2005-2007)
DBA 954X Front Nissan 350Z - Std./Performance/Enthusiast/Touring models (2003-2005)
DBA 574X Rear Nissan 350Z - Std./Performance/Enthusiast/Touring models (2003-2005)
Old Dec 9, 2008 | 06:57 PM
WILLIE BEANS's Avatar
03 G35 Sedan Front/rear dba 4000..rotors Only
Old Dec 9, 2008 | 07:58 PM
All Sent
Old Dec 18, 2008 | 04:20 PM
Dba In Stock Again !!!
Old Dec 18, 2008 | 05:59 PM
1trueG's Avatar
04 coupe with brembos. Can you price me for the dba 4000 cross drilled slotted, and the dba 4000 slotted for both the fronts and rears. Thanks.
Old Dec 26, 2008 | 04:58 PM
All sent
Old Jan 3, 2009 | 03:51 PM
ih8vls's Avatar
g35 2003 with brembo price on dba 4000 sloted rotors and ebc greenstuff pads to suit
shipped to tamworth nsw australia 2340
cheers
Old Feb 16, 2009 | 11:00 PM
robzone's Avatar
Old Mar 13, 2009 | 11:50 AM
richie's Avatar
Do you guys carry OEM brembo replacement rotors (x-drilled) for 04 coupe 6MT?
Old Mar 17, 2009 | 11:10 PM
thatguy II's Avatar
'05 G35 coupe 6MT
how much for front and rear for Hawk HPS, shipped to 74055?
thanks
Old Sep 20, 2009 | 10:51 AM
moe07's Avatar
DBA 4000 Cross Drilled & Slotted Series rears only shipped to 22193
and ebc redstuff rears only
Old Sep 21, 2009 | 11:27 AM
phunkenstein's Avatar
EBC Green Stuff Fronts and Rears (Non-Brembo)
to
21037
(2004 G35 Coupe 5AT Non Brembo)
Old Nov 24, 2009 | 05:46 PM
moe07's Avatar
ebc redstuff g35 coupe non-brembo fronts only please shipped to 22193
Old Dec 2, 2009 | 11:46 PM
racertech's Avatar
PM me a price for DBA 4000 slotted gold hat
03 G35coupe brembo front and rear rotors
