CZP SS Brake Lines $119 Shipped!! - Hawk Performance Pads & Stoptech Rotors @ CZP!
Old Jul 26, 2011 | 10:41 PM
Coz@Czp's Avatar
_________________________
CZP G35 / G37 Teflon Coated Stainless Steel Brake Lines
Description:CZP Stainless Steel Brake Lines provide a quicker pedal response, maintaining consistent brake pressure and precision brake modulation, especially during threshold braking. All CZP Stainless Steel Brake Lines are manufactured to meet DOT Compliance Standards. Our brake lines are coated with a Clear Abrasion Resistant Cover for maximum protection against chaffing. Fits All G35 & G37 Models
*Stoptech Direct Replacement Rotors available at CZP we carry Brembo and Non-Brembo for all years. please specify year and model when purchasing*
Description:SportStop direct replacement rotors fit stock calipers. Drilling or slotting helps wipe away the debris that forms between the pad and the disc, adds more bite, and can help the rear brakes to match the aesthetics of a front Big Brake Kit. The rotor finish helps prevent glazing of the pads, and improves wet and dry braking performance. StopTech rotors have a durable black coating on the non-swept areas of the rotor to prevent unsightly corrosion.
Stoptech G35 Direct Replacement Rotors, Slotted (sold as a pair)
Stoptech G35 Direct Replacement Rotors, Drilled(sold as a pair)
Stoptech G35 Direct Replacement Rotors, Drilled/Slotted (sold as a pair)
We also carry a constant supply of Hawk Performance Pads:
Hawk HPS G35 Front Pads
Hawk HP Plus G35 Front Pads
Hawk Performance Ceramic G35 Front Pads
PM me for best pricing or with any questions, please specify year & model.
Old Jul 29, 2011 | 01:35 AM
blk-g35sedan6mt's Avatar
Would you have any drilled/slotted for 05-06 g35 sedan 6mt?
Old Jul 31, 2011 | 01:05 PM
Coz@Czp's Avatar
Bumped!!
Old Aug 4, 2011 | 10:40 PM
Coz@Czp's Avatar
Bumped!!
Old Oct 24, 2011 | 11:15 PM
outcasted g's Avatar
drilled rotors front and rear for brembo shipped to 92704
Old Oct 25, 2011 | 01:48 PM
fillup's Avatar
Will those stainless steel lines work with a 2009 G37S?
NVM, apparently I can't read.
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
RedBaronK
Jul 27, 2015 03:19 PM
mushu
Jul 15, 2015 03:55 PM
