Z1 Motorsports Brake Master Cylinder Brace
Old Jun 24, 2015 | 12:25 PM
Z1Motorsports's Avatar
Z1 Motorsports 350Z / G35 Brake Master Cylinder Brace
Z1 Motorsports Brake Master Cylinder Brace is the premier and most affordable brake upgrade you can buy for your 350Z, G35 Coupe, or G35 Sedan. It is effective for Z's and G's either on the track or in traffic.
When pressing the brake pedal, the force applied is transferred through the pedal assembly and unto the firewall. Although reinforced, the firewall is still easily manipulated. Z1's Brake Master Cylinder Brace provides a halt to this flex by securing the Master Cylinder against a series of solid aluminum brackets fastened through the false firewall and directly to the driver side strut tower.
If you are not convinced of the need for such an accessory, grab a friend and pop the hood or your Z or G. Remove any covers around your brake Master Cylinder. Have your friend sit in the driver's seat and press hard on the brake pedal a few times. Watch the Master Cylinder move towards the front of the car with each press of the pedal.
Unlike similar products, Z1's Brake Master Cylinder Brace is a simple bolt-on solution (no machining required!) and eliminates ALL of the firewall flex, giving you the quickest reaction time from when you press the brake pedal to when pressure is applied to the rotors. Couple this brace with high temperature fluid, braided stainless brake lines, upgraded pads, and rotors, as found in Z1's Brake Upgrade Packages, and completely transform your braking experience.
Features:
  • CNC Machined Billet Aluminum Black Hard Anodized Base
  • Precision Investment Cast Aluminum Black Stopper Arm
  • Yellow Zinc Coated Custom Hardware
  • Integrated Clutch Master Cylinder Reservoir Mount
  • Installs in less than 30 minutes!
  • Detailed Installation Instructions
As you can see from the installed picture, the bracket fitting the clutch reservoir has been eliminated and replaced by the cast aluminum arm. Z1 includes all of the necessary hardware to mount your reservoir to this arm.
Please Note:
This brace can NOT be used with any aftermarket strut mounted chassis brace.
You can find this HERE
Old Jul 8, 2015 | 10:21 AM
In stock
Old Jul 8, 2015 | 03:31 PM
Thanks for the orders guys, keep them coming.
Old Jul 10, 2015 | 12:27 PM
Bump
Old Jul 13, 2015 | 02:21 PM
Bump
Old Jul 14, 2015 | 11:02 AM
Upgrade your track or street application and illuminate play in the brake system.
Old Jul 17, 2015 | 11:14 AM
In stock
Old Jul 22, 2015 | 10:06 AM
Bump
Old Jul 23, 2015 | 03:09 PM
In stock
Old Jul 27, 2015 | 10:18 AM
Bump
Old Jul 28, 2015 | 11:47 AM
Bump
Old Jul 29, 2015 | 03:35 PM
In stock
Old Jul 31, 2015 | 05:02 PM
Sharpen your brake response with the brake master cylinder brace.
Old Aug 3, 2015 | 10:21 AM
Increase your initial brake response.
Old Aug 6, 2015 | 11:59 AM
Bump
