FS: Stoptech replacement 2 piece rear rotors for OEM brembo setup
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
This is a used set of rear stoptech 2 piece rotors for the OEM brembo setup (322mmx22mm). Just selling the rotor portion, not the hat. They have just over 21 mm thickness. New is 22mm, on the rotor it says minimum width is 20.2mm. So they have about 50% life left. Brakes were daily driven, no tracking. Neither one is warped.
I just want to clean out the garage, so only asking $5 OBO picked up in Socal. PM me if you want them shipped.
There are some grease marks on the rotors.
This is for the rear rotors. Instead of the heavier one piece rotor, this replaces the outer portion of the lighter stoptech 2 piece rotors. You'll need the aluminum hats if you don't have them already. I have the old mounting screws/nuts, but its recommended to use new ones when you put together a 2 piece rotor.
mjfenix
Aug 17, 2017 05:49 AM
