FS: Nissan GTR R34 Front and Rear Brembo BBK 4pot/2pot
Old Aug 14, 2010 | 04:20 PM
TopSpeedAutoSport's Avatar
Selling both Front (4pot) and Rear Brembo BBK (2pot). Can fit any car with custom-fitted brackets. in excellent condition. want $1200 OBO for them.
Old Aug 14, 2010 | 04:32 PM
socialconflicts's Avatar
wow what a deal, they clean super clean too! GLWS
Old Aug 14, 2010 | 05:56 PM
Xet's Avatar
Xet
does your shop have any ability to make the brackets or source the brackets needed to make these fit on a g?
Old Aug 14, 2010 | 05:58 PM
Unfortunately no sorry, just selling these seperately
Old Aug 15, 2010 | 03:21 PM
Blue Dream's Avatar
I drove ttrank's car solo
Are the rotors included? If so how many miles on them?
Old Aug 19, 2010 | 02:51 AM
Tunerz_Store's Avatar
NO need for a bracket, these should bolt directly onto any z or g.
Old Aug 19, 2010 | 03:32 AM
Xet's Avatar
Xet
any reference for this?
Old Aug 19, 2010 | 03:52 AM
They are the same size rotor diameter wise as the 350z/g35 brembo. Only difference is 2mm of thickness of the rotor. So you will have 1mm more space between pad surface and rotor face when using a 350z/g35 brembo rotor.
These bolt up to z32's. I have personally bolted up r33 brakes to my g and they fit exactly how they were suppose to and they also also fit on z32's.
Have the OP measure between the bolt holes. I guarantee they are the same as the 350z/g35 brembo caliper.
Old Aug 20, 2010 | 06:45 AM
Blue Dream's Avatar
Op???
Old Aug 20, 2010 | 10:47 AM
andrewyfang's Avatar
So you're saying these bolt on?
Old Aug 21, 2010 | 11:58 PM
Hi,
The rotors are included.
Rotors have 15,000 miles and brake pads have 8000 miles.
Thanks!
Topspeed Autosport1
Old Aug 22, 2010 | 12:05 AM
I think Brembo can special make a bracket for any car, if you are very interested in these brakes, you can ask Brembo for more details.
Or you can custom make a bracket from machine shop.
Thanks!
Old Aug 22, 2010 | 02:28 PM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
I'm pretty sure that Brembo won't make custom brackets for individuals. Unless you're a major race team, most people can barely get responses from them for even smaller issues.
That being said, these probably would bolt up to a g35/350z. The front caliper mounting bolt distance on the G35 is 10 cm. The only thing that you may need to worry about is the offset, so you might need some shims to get them to sit perfectly on a g35/350z.
Old Aug 22, 2010 | 03:08 PM
pattyskin's Avatar
I'm pretty sure they don't "bolt right up" to a G35. They should bolt up to a 300z or 240sx though. You may have some luck selling them on Nico club or zilvia forums as well as they're actually in VERY high demand....
Old Aug 22, 2010 | 11:57 PM
E_K's Avatar
E_K
I looked through some saved pics on my computer, and it looks like the faces of the calipers are the same, but the mounting area is different. So pattyskin is probably right.
First attachment is a R34 brembo. Second is of a 350z/g35.
Attached Thumbnails Nissan GTR R34 Front and Rear Brembo BBK 4pot/2pot-post-a297957-mg-1094.jpg   Nissan GTR R34 Front and Rear Brembo BBK 4pot/2pot-brembo-stock2.jpg
