FS: BNIB Stoptech Stage II Sport Kit
Old Jan 13, 2012 | 11:58 AM
Kim@Forged's Avatar
Hello g35driver,
Our one-off open clearance continues, we found a brand new in box Stoptech stage II sport kit for 350Z/G35 during out last round of winter/spring cleaning. It is for non-brembo applications.
This is a great upgrade for those not quite ready to step up to a big brake kit, but still provides a tremendous improvement in braking power, for not much money. The Stop Tech Stage II Kit includes a full set of slotted rotors, stainless steel brake lines, high performance brake pads.
Get maximum braking performance when you use a complete StopTech Brake Kit with Power Slot Rotors
Each kit includes StopTech Power Slot Rotors, StopTech Street Performance Brake Pads, and Stainless Steel Brake Lines
All implements packaged as a group of four: one of each for every wheel
Cast-iron Power Slot rotors resist glazing and eliminate debris accumulation for full contact stopping with an aggressive initial bite in all conditions
Rotor slots and veins protect against thermal cracking
Brake pads maintain friction for trustworthy braking whether you are racing or Sunday cruising; brake lines designed to resist expansion and maintain integrity through years and years of use
Custom-designed for each particular vehicle, each kit installs directly to stock calipers
Black coating on non-swept areas prevents corrosion
Everything needed for installation will be included in each package, and everything is designed to work together
StopTech's Power Slot rotors feature directional slots and cooling veins that guard the rotor against cracking in high-stress, high-performance situations. Teaming them up with a full brake kit, as you can do with a StopTech Brake Kit with Power Slot Rotors, ensures your vehicle's brakes will be ready for everything.
Each braking system is custom-designed to your vehicle's exact specifications. With this system, you'll receive four sets of StopTech Power Slot Rotors, StopTech Street Performance Brake Pads, and StopTech Stainless Steel Brake Lines, one full brake set for each of your wheels. Even better, everything installs directly to your stock calipers. No matter the conditions, your braking performance will improve dramatically. A StopTech Brake Kit with Power Slot Rotors prevents the deleterious effects of glazing on your braking system, ensuring ample bite and response while also protecting your vehicle against thermal cracking. Corrosion-resistant and substantially more aggressive than your stock brakes could ever hope to be, you'll find everything you need to install these brakes included in one convenient package.
StopTech 977.42001 fits:
2004 Infiniti G35
2003 Infiniti G35
2002 Infiniti G35
2005 Nissan 350Z
2004 Nissan 350Z
2003 Nissan 350Z
2002 Nissan 350Z
This one IN STOCK unit is only 555$ shipped!
This price for a complete brake upgrade is absolutely unheard of...won't last long!
Old Feb 2, 2012 | 12:31 PM
Straightkill's Avatar
Really considering this...
Old Feb 8, 2012 | 05:45 PM
mephistomyhero's Avatar
So, these won't work on 2005 coupes...or any coupes for that matter?
Old Feb 14, 2012 | 12:58 PM
moose0422's Avatar
Stoptech Brakes
Are you willing to part this out?
Old Feb 17, 2012 | 06:31 PM
HerG35_661's Avatar
What parts do you want^^?
Old Feb 20, 2012 | 10:23 AM
Kim@Forged's Avatar
Sold
jsimonk
Dec 22, 2023 03:49 PM
R350k5
Oct 1, 2015 08:41 PM
linedr89
Aug 17, 2015 05:11 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
