FS: Evo Brembo 4 Piston Brake Calipers w/Stoptech Pads & G35 350Z BRACKET & ROTORS
Old Jan 14, 2023 | 04:21 PM
jefferywdonald's Avatar
Work In Progress
Evo 8 9 Front Brembo 4 Piston Brake Calipers w/Stoptech Pads & G35 350Z BRACKET
These Brembo 4 piston calipers are originally from a Mitsubishi EVO 8/9. A bracket was made so they could be mounted on a G35 or 350Z knuckle. The knuckle will need to be partially shaved in order to fit these. I bought my G35 used and didn't find out the calipers were swapped until I went to replace the pads and they were a different size. I replaced these EVO Brembos with Power Stop calipers that were meant for my G35. These Brembos are slightly larger though. I'm not sure what rotors the previous owner used because when I tried to install new rotors they were just a few mm too large. I don't know if they were the rotors off the EVO. I will include the rotors as well if the buyer wants them.
So these calipers are working and have no issues. They can be used on a G35 or 350Z with a little modification to the knuckle and making sure there is enough clearance for the rotor to rotate without rubbing. Or the home-made bracket can be taken off and the calipers can go back on an EVO or used however you'd like.
Each caliper has brand new bleeders, no stuck or stripped bleeders, all threads great condition.
Calipers come with stoptech street pads (Part # 308.10010) with a very good amount of pad life still left. I used these calipers for almost 3 years without issue. If you don't want the rotors let me know and I can reduce price.
THIS LISTING IS FOR THE FOLLOWING
- 2 BREMBO FRONT 4 PISTON CALIPERS
- STOPTECH STREET PADS (Part # 308.10010)
- 2 ROTORS (THESE ROTORS WORK FOR G35/350Z, I DON'T KNOW WHAT/WHERE THEY ACTUALLY CAME FROM. STOCK ROTORS WILL NOT WORK WITH THESE CALIPERS IF USING ON G35/350Z SEE DIFFERENCES IN LAST PICTURES)
IF YOU ARE GOING TO USE THESE ON A G35 OR 350Z YOU HAVE TO SHAVE THE KNUCKLE. IF YOU WANT PICTURES OF THE KNUCKLE LET ME KNOW. I WILL NOT ACCEPT RETURNS. ALL ITEMS SOLD AS IS.
Asking $400 - open to offers
Old Jan 14, 2023 | 09:45 PM
Urbanengineer's Avatar
Neat that it bolts up. Glws, never seen this swap over, glad to know another platform that will!
Old Feb 8, 2023 | 04:37 PM
Work In Progress
Bump, lowered price $400
naut
Brakes
Jul 12, 2014 07:10 PM
35Alive
Brakes
Feb 9, 2013 10:02 AM
Hi-TechG35
Brakes
12
Jun 19, 2011 02:03 PM
socialconflicts
Archived Sales
16
May 10, 2010 11:20 AM
turbokanji
Archived Sales
Apr 16, 2010 09:34 PM
