Buying, Selling & Leasing Discussion Interested in getting a G35? Ask your questions here! (No Classified Posts)
Click This Please - Buying a G35 Coupe 6MT
Old Sep 2, 2014 | 05:53 PM
TreeFiddy's Avatar
Update: Hey everyone, thanks for your input, I'm trying to be patient and not spring on the wrong car but that's sooooo not me. I am looking at another one though that has less miles and it appears to be clean, it is modified though which is a bit of a turn off to me. Here she is: http://providence.craigslist.org/cto/4630616805.html
He said that car hasn't been inspected. Where are the cats on this car? Would the Stillen headers delete them meaning I wouldn't pass emissions? These are things I should have asked the guy when I was on the phone with him 5 min ago.
Old Sep 2, 2014 | 06:06 PM
BeyondInfiniti's Avatar
I approve of all those modifications. Very clean, very nice. Good brand parts. It may ride a bit stiff with the bilstein and tein combo. Does it have brembo brakes? Is it an HR? And that low mileage sure is nice but he's asking a bit too much
Old Sep 2, 2014 | 06:09 PM
And about passing emissions. The cats are the downpipe as well as the cats. So no they shouldn't be a car delete. One way to check this is to look under the side skirt right below the wheel and In front of the y pipe and see if there are cars fed by headers.
Old Sep 2, 2014 | 10:53 PM
PLENUMCOUPE's Avatar
Same car as urban and I
Old Sep 2, 2014 | 10:56 PM
Lartytiejdke3's Avatar
Just me or shady reasoning for the inspection?
"Didn't want to make it look older.." The ***?
Here in NJ that's a HUGE no-no
Look into that
Old Sep 2, 2014 | 10:59 PM
TreeFiddy's Avatar
Look into that
Yeah, I don't know what the deal is with that. I talked to him on the phone and he said he didn't know of any reason it wouldn't pass. The tint setup should be legal here in CT, I don't know what the laws in RI are. The only thing I could think of is if he's not running any cats or something along those lines. Does anyone know if putting headers on these cars can make them fail emissions?
Old Sep 2, 2014 | 11:02 PM
it's an 06 so no HR or brembo dude
Old Sep 2, 2014 | 11:03 PM
Aftermarket headers and test pipes will surely not pass smog
Old Sep 3, 2014 | 03:50 PM
headers just improve power, if it has test pipes it will fail... I should know haha! but, chances are if it has test pipes and headers you'll know because it will be loud. But I told you how to check for test pipes already.
Old Sep 3, 2014 | 08:38 PM
TreeFiddy's Avatar
Update: So I drove the original car again, (the one photographed in the first post) and it didn't feel any faster. It's like it has no low end at all. You guys talk about chirping your tires into second and third, there's no way in hell this car would be able to do that. The other thing is I discovered that the heated seats also don't work. I know seats for this car are incredibly expensive, but what would cause neither one to work? Anyway I'm going to test drive the one in RI sometime this week when the guy can actually meet me so we'll see how that one goes.
Old Sep 4, 2014 | 02:39 PM
The problem is that it could be any host of things causing a lack of power. I had to hunt through my engine to find my problem, although mine may be the first of it's kind. And my tip when buying any car. If it doesn't run, only pay for a car that doesn't run. No guarantee of "Oh this little thing is super easy and that's the problem." will get me to buy a car. I wouldn't buy the low power one, I've already made that mistake with my G. And that could be as simple as a blown fuse for those seats.
Old Sep 6, 2014 | 02:21 AM
TreeFiddy's Avatar
Update: So I drove the car in Providence: http://providence.craigslist.org/cto/4630616805.html and I really like it. It drove perfectly and it's in really good shape. The only thing I'd need to have fixed on it is a small dent in the roof, and I'd probably remount the splashguards since the adhesive seems to be failing, but that's relatively minor stuff. Now it does do one thing that I do not like. After starting out in first gear, maybe a second or two after you're completely off the clutch, it makes a noise. The noise is kind of hard to describe, it lasts maybe half a second and only happens in first. The best way I can describe it is it sounds like the noise a car makes when you try to turn it on when it's already on. It isn't accompanied by any vibration or any effect on the car's performance. The car shifts fantastically and when you're idling it's so quiet and vibration free it's difficult to tell if the car is even on. The seller told me that he was told by Infiniti that the sound was due to the lightweight flywheel. Does this sound correct? Has anyone experienced anything like this before? My friend who also drove the car thinks that it is something rattling in the exhaust. What do you guys think?
Old Sep 6, 2014 | 05:50 PM
A lot of people install a lightweight flywheel, I've done it on several cars but not my or anyone else's G35. With that being said there are also a lot of complaints with the lightweight flywheel (LF) I've heard multiple complaints from "It sounds like gravel" to "a little grinding on engagement" So I could believe his excuse for what the sound is. It could also be a host of other things. bad throwout bearing, pilot bearing, input shaft play. But with that being said, it doesn't sound like a big deal.
Old Sep 8, 2014 | 12:37 PM
Ejgold55's Avatar
Light flywheels causes some chatter, but I have an Exedy (who also makes NISMO flywheels) lightweight fly and you really have to listen for the chatter with the AC off, radio off and really try to listen for it at idle, no noise when the clutch is engaged.
The noise when your shifting it sounds like the Throw Out bearing which when that goes will prob ruin the bearing sleeve its on also. And it IS going to fail. $50 in parts......and whatever your shop is going to charge to drop the transmission....then you get into "well i already dropped the trans, might as well replace the flywheel, press plate, clutch disc, slave cylinder...." not that all of that may be necessary, just however far you want to go really, but once you pay for the labor............
Old Sep 8, 2014 | 04:43 PM
  #30
Oh I'm not saying all lightweight flywheels will chatter. But they're a dual mass style OEM for a reason. And speaking of dropping the transmission... I'm going to have to haha! It's not that difficult, but I'm not a fan of how heavy it's going to be.
