Canada Serving Canada.
Alignment question
Old Nov 26, 2006 | 09:29 PM
kimro's Avatar
Alignment question
Hey guys,
I wanted to ask you about my car problem..
My car is pulling to the right and:
- Alignment done. Alignment checks out fine. Nothing major off to cause pull to right.
- Tires are balanced, got the tire guys to check it twice
- Tried rotating tires, every possible combinations (I think)
Now, I don't know what to do..
Any suggestions?
Thank you in advance.
Old Nov 26, 2006 | 09:38 PM
geeboy79's Avatar
Maybe something wrong with your Lower Control Arm or Knuckle Assembly.
Just my guess.
Old Nov 27, 2006 | 09:14 AM
kimro's Avatar
Ur guesses are welcome.. as I have no more ideas
Old Nov 27, 2006 | 09:20 AM
RBull's Avatar
Rated M
Originally Posted by kimro
Hey guys,
Any suggestions?
You should not have to be doing any guesses. The purpose of an alignment is to make sure all steering/components are set up to correctly track the car straight down the road. Any deficiencies in these components should have been picked up in the alignment or the alignment specs were not followed. From what you've described it sounds like they did things right but there has to be something missed or wrong.
Simple answer- take it back where you got the alignment and have it corrected or take it somewhere else you can trust.
G/L
Old Nov 27, 2006 | 02:07 PM
kimro's Avatar
Thank you!!
Old Nov 27, 2006 | 02:13 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
G/L
+1...
alignment should be more than just making adjustments.
- components should be checked as well.
& a test drive should follow.
You can ask to go on the test drive to point out what the problem is.
Old Nov 27, 2006 | 02:20 PM
35bills's Avatar
Kimro,
Did you by the car used?
Was an info sheet given to you about the vehicles history? An accidents if any?
What dealership did you go to for the alignment?
Old Nov 27, 2006 | 02:50 PM
kimro's Avatar
Yes I got the car used, no accident recorded, clean carfax.
I got it from Downtown Mazda.
I went to AlignTech at Kipling & Rexdale.
rezendvous420
May 31, 2020 01:26 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 23, 2015 09:26 AM
Soumilg
Jul 18, 2015 12:33 PM
