Canada Serving Canada.
Dash lights changing intensity
Old Jan 18, 2007 | 09:52 PM
whatacar's Avatar
My dash lights seem to change intensity by themselves for no reason. I've had them checked out by the stealership. They found notning but reprogrammed them just to be sure. Still does it. Any thoughts?
Old Jan 18, 2007 | 09:57 PM
filanj's Avatar
maybe you're accidentally rubbing the control scroller. it's near/next to you VDC button. roll it all the way .... eh... one way dims one way brightens.. the way that brightens should click at the very top/bottom and it'll be on auto
Old Jan 18, 2007 | 10:05 PM
whatacar's Avatar
Possible, I'll keep an eye on my knee. I think thats the only body part that
could reach.
Thanks
Old Jan 18, 2007 | 10:09 PM
filanj's Avatar
no problem. I did the same thing when I first got my coupe. It took me a couple days to figure it out
Old Jan 19, 2007 | 08:11 AM
RBull's Avatar
Rated M
You guys sure must sit close to the dash. There's no way my knee cold reach that control.
Old Jan 19, 2007 | 08:46 AM
giddyup69's Avatar
does this happen at night or day or both? with the headlights off.. the scroll wheel will not affect the dash illumination. are u sure that it's just not your auto headlights coming in while u pass under a bridge or something? any time your lights come on ... your dash lights should dim ... unless u have the scroll wheel all the way to the top passed the click.
Old Jan 19, 2007 | 08:55 AM
RBull's Avatar
Rated M
Exactly. With the headlights off the dash lights are on full (daytime) illumination. He must be talking about night time unless your suggestion about the auto headlights is happening. The dealer is able to adjust the sensitivity to the outdoor light with three different settings.
Old Jan 19, 2007 | 10:25 AM
Msedanman's Avatar
O.F. Administrator
could reach.
Thanks
From what I saw last Saturday, Sam, the adjutment wheel on the dash was very loose just like the '03 coupe I had.... -- which means a faulty dimmer adjuster.
I think you'll find that you can make the problem come and go by just touching that adjutment wheel.
I believe that wheel gets loose by jarring of bumps over the years of driving.
If the dealer won't replace that wheel (which is attached to a rheostat I think), you'll have to experiment with somehow tightening that wheel by setting it and pushing something in between the wheel and the housing to see if the unwanted light variance disappears....
It sounds crude but I believe that to be the issue and it will at least tell you where the problem is.
I can't see that adjuster being very expensive......but who knows these days...
could reach.
Thanks
LOL, Sam.....you're bragging again......
G/L
C.
Old Jan 19, 2007 | 06:26 PM
whatacar's Avatar
This happens anytime, first thing as I go to work or late at night. I always have the setting on auto.
Old Jan 19, 2007 | 06:27 PM
whatacar's Avatar
I'll have to check which setting the dealer used.
Old Jan 19, 2007 | 06:29 PM
whatacar's Avatar
G/L
C.
Interesting, I'll check it out. BTW not possibe to hit the wheel with my knee or anything else from where I have the seat.
Old Jan 19, 2007 | 10:18 PM
irshadow's Avatar
I have the same problem, but it it only happens in that little box w/ my mileage adn sucha nd the right area of my dash.
Old Jan 19, 2007 | 11:58 PM
whatacar's Avatar
Is the right area the set of lights showing temperature and such?
Old Jan 20, 2007 | 12:28 AM
God|ZIlla168's Avatar
could reach.
Thanks
Might be his other body parts but i really don't want to know why it would be out.
Old Jan 20, 2007 | 12:32 AM
VQ Hotness's Avatar
HA ha, I would love to see what the dealership calls Reprogramming them.
