Canada Serving Canada.
2GB Compact Flash Cards
Old Jan 27, 2007 | 09:40 PM
G35-2-B's Avatar
Just took a quick look at CF cards - quite a price spread -
Sandisk Ultra II 2GB 9MB/sec Compact Flash Card - $82.99
Sandisk 2GB Compact Flash Card - $69.99
A-DATA Compact Flash Card TM - $50.99
Kingston 2GB Compact Flash Card - $44.99
Crucial 2GB Compact Flash Card - $38.99
Transcend 2GB 80x Compact Flash Card - $38.99
The Cruicial seems the best buy of the bunch - ie known name; lifetime warranty, most reasonable. Any one have it and are there any problems with it ?
Old Jan 27, 2007 | 11:21 PM
Oggie's Avatar
You need to look at the performance of these cards. I believe Sandisk Ultra II is one of the top performers in this category. Check CanadaComputers.com for their prices. They might be cheaper than what you have quoted.
Old Jan 27, 2007 | 11:29 PM
JayEazy's Avatar
Sandisk EXTREME III is the best
Old Jan 28, 2007 | 12:07 AM
G35-2-B's Avatar
You are correct ( other than III and IV),...
Extreme IV ??? 40 mb/sec
Extreme III ??? 20 mb/sec
Sandisk Ultra II 2GB 60x 9 mb/sec
Sandisk 2GB ??? ???
A-DATA ??? ???
Kingston ??? ???
Crucial 2GB 40x 6 mb/s
Transcend 2GB 80x 12 mb/s
Old Jan 28, 2007 | 02:29 AM
RA031524's Avatar
If your using these with a digital camera, check out Rob Galbraith's website (http://www.robgalbraith.com/bins/mul....asp?cid=6007).
He regularly benchmarks CF/SD cards against various cameras. Just because a card says 80x or higher, doesn't mean you will get that speed with your camera. Don't pay for more speed if you don't need it.
Old Jan 28, 2007 | 10:26 AM
G35-2-B's Avatar
As its use in the G is primarily (or entirely) audio, is there a performance point where you just wont hear the difference...or notice the reduced delay in loading??
Old Jan 30, 2007 | 10:24 AM
RA031524's Avatar
You will want to look at the read rates of these cards. For typical MP3 playback, they will be more than adequate to deliver the bit rates needed to play back 192 Kbps mp3 files. All CF/SD cards have read rates in the number of MB/s, you only need to stream a few hundred K bits.
So, spend you money on capacity rather than speed here. Of course, speed will help when you want to bulk transfer music files between the card and your computer. Get a good fast USB 2 or Firewire card reader when you get order your card.
costco.ca and tigerdirect.ca have good prices on cards.
Old Jan 30, 2007 | 10:36 AM
G35-2-B's Avatar
thanks. I ended up with the Transcend 2GB 80x 12 mb/s card - under $40 CDN. Also lifetime warranty.
Old Jan 30, 2007 | 11:22 AM
Garnet Canuck's Avatar
Traveling Administrator
I am currently using dual Cruicial 2GB CF cards in my G and I have found they work fine. I paid $24US each for mine.
Old Jan 30, 2007 | 02:22 PM
giddyup69's Avatar
if u want.. u can also get a Kingston 4GB Elite Pro for $97.17
Old Jan 30, 2007 | 04:10 PM
Unfortunately, getting a 4BG CF card for the G is pointless, since the CF card is llimited to 512 files when played in the G. That is the reason I got two 2GB CF cards.
Old Jan 31, 2007 | 02:58 PM
giddyup69's Avatar
hmmm. that sucks on the file limit. but u could still fill a 4gb card. i could do it with some of my stuff and still be well under 512. example.. long song length and high bit rate will do it.
something interesting though... without navigation, u can hold up to 999 files. hmmmm... i guess it must be some sort of ram issue.
Thebaws11
Jul 2, 2021 11:36 AM
