Canada Serving Canada.
SPC camber kits
Old Mar 29, 2007 | 05:11 PM
SammyJL's Avatar
SPC camber kits
Hey guys/gals, I just ordered the front and rear camber/toe kits from IAPDirect in Florida. They have a great sale on right now until the 31st. Have a look in the marketplace if you are interested.
Has anyone here in Canada tried these parts yet? I'm getting tired of chewing up my S-03's.
I think I am going to put on my Nitto 555's that I got for cheap, until I get these alignment issues fixed.
Just thought I'd let you know.
Old Mar 29, 2007 | 05:28 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
I had a set Sam, but never installed them.
They looked pretty straight forward...... just a bolt & larger cam to adjust.
I think there's a little filing (dremel) to do, to give the cam enough space to rotate.
Should do the trick.
Old Mar 29, 2007 | 05:47 PM
Alan's Avatar
on a side note it makes me sad that S03's are discontinued.
Old Mar 29, 2007 | 07:34 PM
SammyJL's Avatar
WHAT????? That sucks big time as I was going to purchase some more rears because the fronts are fine.
What are the chances that someone somewhere has 2 rear tires that match my size (Potenza S-03 285/30ZR20) for sale? I did a search on eBay but had no luck.
Old Mar 29, 2007 | 09:29 PM
Gordon's Avatar
Hi Sam,
I have these parts sitting at home waiting to be installed on Ben's car, including a set of Tokico D-Spec's with Eibach Prokit springs.
Do you know where you are going to get the kit installed?? Was looking for a place because there is some dremelling involved to install the rear toe bolts.
Old Mar 29, 2007 | 09:47 PM
SammyJL's Avatar
I'll probably just take it to my local mechanic if I can't do it myself. It looks pretty straight forward. The dremeling isn't that bad because they give you a template to use so that you don't make any mistakes. The front control arms will probably be done by my mechanic, we'll see.
Old Mar 30, 2007 | 12:02 AM
alphabit's Avatar
I just had my SPC camber kit, front and rear installed along with my coils today at http://www.simoneperformance.com.
They take good care of you. Ask for Steve or Vic
Old Apr 8, 2007 | 03:10 PM
Gordon's Avatar
Hi Alphabit,
If you don't mind me asking, how much did simoneperformance charge you to install the camber kit along with the coils?
Old Apr 8, 2007 | 11:13 PM
God|ZIlla168's Avatar
I thought the SPC front was not a great front camber kit?
Old Apr 8, 2007 | 11:16 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
it is a very good camber kit... for the G sedans and 350Z's... the coupe however, for some odd reason, has some problems with the kit. One of our members is currently testing out the revised a-arms, if all goes well then the revised arms should be in production by the end of the month.
-GP-
Old Apr 8, 2007 | 11:34 PM
Love thouse gold rims, waiting to put mine on once the damn weather is better up here
Old Apr 9, 2007 | 12:33 AM
alphabit's Avatar
I have had mine on for roughly 2 weeks now and have not experienced any problems.
Old Apr 9, 2007 | 06:02 PM
Well if i remember correctly there was a member with the spc front and the thing cracked and screw his suspension up. That is why I am going with the 350evo camber cost more but is proven reliable at least
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
jsimonk
Steering & Suspension
Sep 2, 2015 03:07 PM
