Ariel Atom Driving Experience - who's in?
Originally Posted by Msedanman
Nope, not too early....Sounds good, Sam......We must remember to tell Ian when he returns....
Roman, is that cool with you too?
C.
C.
I'm here.... That works perfectly for me.
I'll be coming through Port Perry & down Waverly right to the 5th wheel.
C.
I've been checking the map and your way might just be the answer for us too to avoid the possible mess on the 401......
Your place is about an hour from me so leaving here at 6 should work, and then Bowmanville looks to be about an hour from your place ...........
You thinking of leaving about 7-ish?
Colin.
Ian,
Colin.
Colin.
but 7-ish sounds about right.
I haven't given it much thought yet.... still catching up to things;
I know Deane is an early riser......
C.
I'll plan on hooking up with you that morning if I can roust Sam out of bed early enough
C.
C.
C.
C.
Originally Posted by giddyup69
damn... 8am huh? i guess that should be ok lol. i'm still not sure which route i'm gonna take to get down there. hopefully there won't be any problems. i'm gonna look at some routes early next week and verify everything with u guys.
You're about an hour from Bowmanville right?
C.
Roman, you might be fine on the 401 from where you are...........Coming into Mississauga/GTA area from Cambridge can be tough on the west end tho, so skirting around that might be best for me...
C.
C.
Won't be long now guys
Roman, Hope to see you (and Sam) for breckie in Bowmanville at 8. We should be there from about 8 til about 9.......
C.
Make sure you have an extra pair of shorts..... could get scary out there.
LOL, good advice. I truly hope none of us needs a Depends or a change though.
