Canada Serving Canada.
Anyone interested in a KW area meet?
Old May 8, 2008 | 05:58 PM
hullio's Avatar
Damn Guelph is too far for me to drive. Have a good time guys.
Old May 8, 2008 | 07:56 PM
GEE35FX's Avatar
What you talkin about Willis. ???
Come on Hullio, the closest meet I ever go to is 1 3/4 hours away and a lot of them are 3 hours away.Get in that X and do what you are supposed to do in it...........DRIVE IT.
Wayne
Old May 8, 2008 | 08:00 PM
RBull's Avatar
Rated M
Wayne
That's a blast from the past!!
So true Hullio. Get in that X and hook up with the boys.
Old May 8, 2008 | 10:54 PM
whatacar's Avatar
WHS X 6. The G's such a blast to drive. If the meet is going to be in Guelph, anyone wanna hook up and convoy over to where ever?
Old May 9, 2008 | 09:13 AM
knight_yyz's Avatar
Originally Posted by G-MAN (CANADA)
Sure Ray I know my Bro will bring his Maxima to get done plus others.
Oh got a question for you I noticed the Idle a little rough sometimes since the Timming adv. is that normal?
I may have to hook you up again and do the idle relearn, it happens rarely, probably due to the extra mods you have. It may go away as the ECU starts to learn with the new settings. If it hasn't gone away by the time I see you next I'll hook up and do the relearn procedure, or you can use the manual procedure to see if it helps.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
5. Conform that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications.
Old May 9, 2008 | 09:21 AM
rpm&my_G35's Avatar
A convoy to Guelph sounds good to me. Just let me know when and where.
btw G-MAN, thanks for the mothers day reminder. You saved me some serious embarrassment on the home front.
Paul
Old May 9, 2008 | 09:19 PM
G-MAN (CANADA)'s Avatar
Paul
no problem.
Ray I'll give it a try but last time I tried to do that I couldn't get it.
Old May 10, 2008 | 08:42 AM
Msedanman's Avatar
O.F. Administrator
Sounds good, Sam.......
C.
Old May 10, 2008 | 10:20 AM
whatacar's Avatar
Now all we need is a date and time Boyz. If it's on a weekend, early in the am works best for me, but I'm flexible.
Old May 10, 2008 | 10:30 AM
OK how about either Sat around 12pm or Mon at the same time? cmon guys we need to agree on a day and time.
Old May 10, 2008 | 11:44 AM
knight_yyz's Avatar
Monday the 19th?
Old May 10, 2008 | 02:58 PM
whatacar's Avatar
Can't make a Mon. 12 - 3 until July
Old May 10, 2008 | 03:35 PM
Originally Posted by knight_yyz
Monday the 19th?
+1 sounds good to me.
Old May 10, 2008 | 10:10 PM
rpm&my_G35's Avatar
19th is ok but weekends are better for me.
Old May 12, 2008 | 03:12 PM
  #30
Thats ok cause the 19th is a holiday
