How to wire up your G seminar?
k maybe i lied, ahah i might come, LOL im not getting and audio from my speakers. Since i have the bose system do i need a special PAC adapter to connect the double din or will any metra, scooche or worlds best harness kits harness do it?
Hey Fire, sorry man just revisited this thread to see if there had been any updates...
What harness were you using - one with rcas or full stranded wires?
you should have connected the blue/white from the aftermarket deck harness to the blue on the harness that plugs into the factory wiring. - that turns the bose amp on
i did
Everythings done right, even rechecked the ground and made sure all the random wires wee rite to other then the rears. I checked yesterdai to and noticed that the left rear has not wired properly so i fixed it but i made no difference at all :S
try this. fade to each speaker individually. front speakers should sound the same, rear speakers will only play lower frequencies so listen closely for discrepancies between them
I didnt use a LOC, do i need to? Im using all stock speaker and ill i did is upgrade the HU to a double din Kenwood, is it still needed? Maybe thats why im not gettting the boom boom
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
