Canada Serving Canada.
Will.i.rub.ADVICE.pls.
Old Aug 12, 2009 | 04:15 PM
LR-G's Avatar
Question Will.i.rub.ADVICE.pls.
Applied here for some local/canadian help.
Hello,
Summary:
I finally found my TENZOs TYPE M 19x8.5 and 19x10 in the rear.
I am lowered enough just above the rear tire and front tire.
Maybe a tad more in the front.
With 275/40/19 in the rear will I RUB?
With 245/40/19 in the front will I RUB?
offsets are +17 in the front and +22 in the rear.
VERY ADVANCE THANKS.
Old Aug 12, 2009 | 04:59 PM
boi's Avatar
boi
No ..................
Old Aug 12, 2009 | 06:36 PM
Sylvan lake V35's Avatar
Without offsets we can't say for sure. The wheels are not very big either are the tires so unless you got some custom super low offsets you should be fine.
Old Aug 13, 2009 | 09:27 AM
gcoupe_toronto's Avatar
I am running 255/35/20 and 285/30/20 with roughly a 2.2" drop and factor in the coilovers settling in, I rub in the front only if I take a speed bump or getting onto my driveway to quickly
40series is pretty big don't your rims look smaller?
Old Aug 20, 2009 | 05:21 PM
t7n7's Avatar
running 245/35/19 275/35/19 , around a 2" drop ... no rubbing HOWEVER, when there are 3 passengers in the car, it will rub a bit when going over a bump a lil too fast.
