Canada Serving Canada.
Calgary weigh station...
Old Nov 10, 2009 | 01:34 AM
6MTKeith's Avatar
A friend and I were driving south to Okatokes and decided to weigh our cars at the weigh station. It said i (04 sedan 6mt) weighed 1590kg with me out of the car and a full tank of gas. His car (09 Audi A3 2.0t Q) weighed 1620kg. Does that seem light fr a sedan? His weight seems preety on, but i thought the sedans were a couple hundred pounds heavier???
Anybody weighed their car at a weigh station? What'd yours come up as?
Old Nov 10, 2009 | 10:21 AM
canucklehead's Avatar
mine weighed 3600lbs with me in it (~195lbs) and a 1/3 tank of fuel. so yours at 3500lbs w/out driver seems about right.
when you say you "thought the sedans were a couple hundred pounds heavier" what are you referring to? heavier than what? curb weight of the various G models is well documented.
Old Nov 10, 2009 | 11:03 AM
6MTKeith's Avatar
Sorry, I meant a couple hundred pounds heavier than 3500lbs.
Alright, that clears it up. My bad calculations got me thinking about this in the first place. I some how came up with 32**lbs when calculating on my phone. I'm impressed with the G sedans being 3500lbs wet. My legacy was more and seemed like a much smaller car.
Thansk for the confirmation.
Old Nov 10, 2009 | 11:06 AM
Swivel's Avatar
Moderator
We're also lighter than G coupes and take every opportunity to rub that in!
Old Nov 10, 2009 | 11:09 AM
6MTKeith's Avatar
Really?!? Thats where I went wrong thinking sedans would be 37-3800lbs then. Most of the weight threads I saw refered to coupes and I assumed we would be heavier.
Old Nov 10, 2009 | 11:10 AM
JOKER's Avatar
CLUB MODERATOR
hotness is heavy.
Old Nov 10, 2009 | 11:13 AM
for reference, my friend's 2004 350Z weighed in at 3460 on the same scale as mine weighed 3600, both w/driver. he weighs about 220lbs, and i believe he had 1/4 tank.
Old Nov 10, 2009 | 12:09 PM
here's some info i found online which seems to be accurate:
2004 Infiniti G35 Available Trims Trim Information
Base 4dr Sedan
Horsepower:260 @ 6,000 rpm
Torque:260 @ 4,800 rpm
Transmission:5-spd auto w/OD
Curb Weight:3,336 lbs.
Fuel Econ.:18/26 mpg
Base w/Leather 4dr Sedan
Curb Weight:3,369 lbs.
Base w/Leather/6-Speed Manual 4dr Sedan
Transmission:6-spd man w/OD
Curb Weight:3,398 lbs.
Fuel Econ.:20/27 mpg
i think the 6MT weighs more because of the spoiler and Aero bits, and because it is a loaded model (only option is NAV).
Here are the '04 coupe weights:
Base w/Leather 2dr Coupe
Horsepower:280 @ 6,200 rpm
Torque:270 @ 4,800 rpm
Curb Weight:3,442 lbs.
Base w/Leather/6-Speed Manual 2dr Coupe
Curb Weight:3,435 lbs.
Old Nov 10, 2009 | 04:01 PM
6MTKeith's Avatar
Every time i see it written that my car has 260hp/tq rather than 280 it drives me nuts. Seems like more work to detune a car than to leave it alone.
Old Nov 10, 2009 | 04:11 PM
Swivel's Avatar
Moderator
Some say the sedan is 280, they jut put that in the lit so it would seem less than the coupe. I think there may be dyno comparisons to back that up, but I personally haven't seen them.
Old Nov 10, 2009 | 05:07 PM
STCLAIRWEST's Avatar
I heard the 03-04 is under rated also because we have the same engine as the 05-06 and they got 280.
Old Nov 10, 2009 | 05:11 PM
Swivel's Avatar
Moderator
Unfortunately early 03's like mine have the Maxima ECU so may actually be 260 I dunno.
Old Nov 11, 2009 | 12:15 PM
6MTKeith's Avatar
I'd really like to see dyno results too. Searched a bit and theres just too many "dyno" results for other reasons. I don't think my car has 280hp though, its just not that fast. Anybody ever try to organize a dyno day?
wow600rr
Sep 28, 2015 11:50 AM
3-fity
Steering & Suspension
Sep 20, 2015 05:05 PM
Frostbite91
Aug 2, 2015 04:59 PM
Mikey35
Canada
Apr 7, 2004 07:45 PM
LMaz
Canada
Jul 14, 2003 10:00 PM
