Canada Serving Canada.
help with painting headlight housings black and painting grill black
Old Mar 30, 2010 | 07:15 AM
pwrobel's Avatar
it is easier to just use a heat gun than putting the whole headlamp in the oven. all you have to do is remove the three little screws in the back of headlamp and heat slowly around where the urethane is and peel back the lense. very easy. done it 4 times already.
Old Mar 30, 2010 | 07:20 AM
Shawn87's Avatar
That is an option... i found that in the oven its easier to peel the lens off in one piece rather than heating inch by inch
I think some people are afraid of melting the housing tho....
When you put it back together with the heat gun does it seal just as well as evenly heated in the oven??
Old Mar 30, 2010 | 07:22 AM
pwrobel's Avatar
sure it does, and why would you heat it after?
Old Mar 30, 2010 | 12:46 PM
Sylvan lake V35's Avatar
So the existing sealant gets soft and helps reseal the housing.
PS oven is 10x easier than a heat gun, the only reason to use a heat gun is if your scared to melt them in the oven.
Old Mar 30, 2010 | 02:21 PM
Shawn87's Avatar
Old Mar 30, 2010 | 04:24 PM
gshock's Avatar
you guys are pro'z that can do it themselves, hehh
i should have mine done soon, ill be sure to post pics!!!
Old Mar 30, 2010 | 09:30 PM
Originally Posted by Shawn87
Sorry pretty much posted the same as you.
Hardly call myself a pro but I have an astounding lack of fear and common sense, for every 4-5 DIYs I have done with positive results I have at least 1-2 that were utter failures. When DIY you must be willing to accept that you might fail and it may cost you more money than if you had it done by a pro in the first place. If you can accept that you can be a DIYer. My DIY don't always go as planned I have replaced virtually every moving component on the car. No one Alberta even thinks I have a car, its broken due to my failures more than it runs. However I get feel alot of pride knowing that 90% of the bolts on my car have now been turned by me. If it ever runs again its not because I am a pro but because I am among the most stubborn people on the planet and I refuse to let anything make me give up although this car is very close to beating me.
Please post some pictures when you get them back!
Old Mar 31, 2010 | 08:12 AM
Shawn87's Avatar
I agree... overlays were a complete FAILURE... every other diy ive tried has turned out pretty decent!!!
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
StreetStandard
Exhaust-Vendor
11
Jan 12, 2016 03:21 PM
bickfordbft
Jul 20, 2015 07:57 PM
realtalk21
Jul 20, 2015 09:07 AM
