Canada Serving Canada.
Compression rods changed - man...what a difference
Old Apr 28, 2010 | 03:12 PM
elrooko's Avatar
So I have been suspecting that my compression rods were bad for the past little while. Ever since I lowered my car with the PSS10 kit, I noticed an occasional knocking which I assumed was one of the rods but in the back of my mind I wasn't entirely sure it wasn't one of the new shocks which may have been defective. When I had the car up on stands I looked at the top of the CR bushings and both were ripped. Got new ones from Riverside Infiniti for about 160 a side and VOILA car drives like brand new.
Should have done it long ago. I tried to DIY it but failed. The bushings were totally siezed and no force I could impart on them would remove them from the siezed bolt. I broke down, bent over, took my medicine and went to the dealer. They charged me $366 tax-in to remove them and re-install the new ones I purchased.
Old Apr 28, 2010 | 03:14 PM
STCLAIRWEST's Avatar
366 not including parts? Did you change both of them?
Old Apr 28, 2010 | 03:15 PM
elrooko's Avatar
Yeah I changed them both.
Old Apr 28, 2010 | 03:37 PM
zeadlots's Avatar
Dam, I wish your DIY had worked. I will need to do this at some point and I want to do it myself. Perhaps you should just post the pics you have??
Old Apr 29, 2010 | 08:29 AM
Shawn87's Avatar
The worst part is getting the sleeve off the bolt... we used heat, but the bushing kept catching on fire. Took about an hour but it worked and what a diff!!!
Only recommend DIY'ing it yourself if you have access to a hoist.
Old Apr 29, 2010 | 01:30 PM
netcbc's Avatar
changed mine last year, hope they last....
should've got them changed at APH, they do them all the time and are familiar with our cars, probably would've been half the price for labor
Old Apr 29, 2010 | 06:53 PM
Hearno's Avatar
Can you describe what changed? What was the before and after other than noise?
Old Apr 29, 2010 | 07:05 PM
Jeff92se's Avatar
Red Card Crew
I wonder if coupe = sedan? I'd like to have your old ones.
Old Apr 29, 2010 | 09:44 PM
elrooko's Avatar
There was a CLUNK everytime I went over uneven pavement or tried to turn and there was a bump.
Old Apr 29, 2010 | 09:45 PM
elrooko's Avatar
Actually I have them here. The dealer pretty much beat the crap out of them trying to get them off. I'm going to try to clean them up and practice press fitting new bushings into them.
If you want them, make an offer
Old Apr 30, 2010 | 12:33 AM
netcbc's Avatar
did you put in the 06 projectors yourself, any tips?
Old Apr 30, 2010 | 06:51 AM
RBull's Avatar
Rated M
Good job. It's not much to pay for something that makes such a big difference versus annoying knocks.
How many kms did you get on originals?
Old Apr 30, 2010 | 09:14 AM
elrooko's Avatar
87K but they were probablly done at around 80
Old Apr 30, 2010 | 10:29 AM
gcoupe_toronto's Avatar
^80K is when i started hearing knocking, i'm at 87 now lol
my mechanic said its not my compression rods tho
Could be my endlinks or bushings
Old Apr 30, 2010 | 12:04 PM
elrooko's Avatar
Yep - I put my own projectors in with a lot of help from another member here on the boards. I did up a pretty extensive DIY so if you do go for it, there is good documentation. It isn't for the faint of heart though as there is a lot of wire cutting, splicing and soldering. In the end, if you are comfortable after you read my DIY, then go for it.
