Canada Serving Canada.
What am I going to break next?
Old Jul 7, 2010 | 10:13 PM
audiophool's Avatar
First the windshield, now I've broken the armrest on the driver's door.
Just put some of my (admittedly not insubstantial) weight on my left elbow, right in the center of the padded part. Crack! Fortunately you can't see it, but you can feel it. FML...
Old Jul 7, 2010 | 10:54 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
That's the 1st time I've heard that one.
Possible warrantee?
Old Jul 8, 2010 | 12:45 AM
Sylvan lake V35's Avatar
Don't feel bad today I had a nail in a tire on my 2010 Titan with 28,000km on it I couldn't get the spare down the release chain jammed up. So with all of my patience I totally snapped and put about 249lbs into the little crank deal destroying it, then the tire was half way down so i has to crawl under the truck bench press the spare and hold it up while I slipped the holder side ways through the centre hole all the while thunder was booming in the back ground as rain was approaching fast . So I got the spare on, I get back in the truck and as I sit in the seat I get poked in the shoulder by the steel frame that all of the foam on my "new" truck has worn away from. Just good thing I was alone at the time so no one witnessed may rage 1st hand
On a side note my boss told me I need to take more time off work so I don't became "cranky" because I am known to become irritable if I work for extended periods with no days off (right now I am closing in on 60 days straight). I thought it might not be a good time to share the tire incedent with him!!!
Old Jul 8, 2010 | 08:08 AM
GEE35FX's Avatar
Wow , hopefully you two can shake that black cloud that was hangin over the both of you.
I had a nail in one of my FX 20s yesterday, but all went well with the fix, although it was extremely hot out.
Old Jul 8, 2010 | 08:39 AM
Swivel's Avatar
Moderator
Definitely a rash of bad luck here in AB.
Old Jul 8, 2010 | 09:06 AM
audiophool's Avatar
...I would have thought this part of a car would be designed a tad stronger in order to meet years of use. But maybe warranty (here I come, Ken. )
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
ara777
Oct 25, 2017 01:45 PM
prinny
Nov 22, 2015 11:07 PM
toadfire
Sep 21, 2015 07:15 AM
