Canada Serving Canada.
G sled tramlines like a b-atch
Old Nov 17, 2011 | 07:15 PM
audiophool's Avatar
Now the winters are on, the sled is tramlining like mad. I'm not sure I noticed this last year. Maybe something's loose in the front end? Only 45,000 miles (yes miles).
Old Nov 17, 2011 | 08:49 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Tire wear look OK on the summers?
Old Nov 17, 2011 | 10:57 PM
audiophool's Avatar
Well, the outside shoulders are very worn on the summers, but that's likely due to the front tires being too small and from pushing around corners. Winters are pretty even. You thinking toe? Now that I think about it, it handles a bit squirrelly. Hmmm.
Old Nov 18, 2011 | 09:09 AM
InTgr8r's Avatar
with worn outside edge it sounds like toe out, which also explains the tramlining
Old Dec 7, 2013 | 07:05 AM
WkndWarrior's Avatar
Did you solve this issue?
My outside tire shoulders are worn too. But it's from counter steering to keep my G straight. It tends to lean left or right depending on which way the road is sloping. I've replaced the compression rods but it's still the same. I'm sure if I replaced the suspension and bushings the car will drive straight again.
Old Dec 14, 2013 | 10:55 AM
Swivel's Avatar
Moderator
^^ He solved it, yes. By buying a BMW 5.
Old Dec 14, 2013 | 01:21 PM
That is definitely one way to solve it!
hayaimoto
Dec 8, 2008 01:20 AM
paradigm79
Dec 1, 2008 11:23 PM
trey.hutcheson
Sep 12, 2006 09:16 PM
