TRAMLINING? help guys
Old Nov 25, 2008 | 08:29 PM
hayaimoto's Avatar
Hi everyone,
Just had a question to see if any of you guys experienced this with your sedans, I have a 03 sedan with about 100k and experience "tramlining" (the car tends to fallow or wobble from side to side in the rear) when driving on freeways with grooves or ruts on the surface for rain. Just wanted to see if anyone else has experienced this.
The tires are new as well, NEXEN N5000's and the car currently had the alignment done.
Think its time for new shocks?
Thanks in advanced guys!
Old Nov 25, 2008 | 10:16 PM
XXDANNYXX's Avatar
dude im having the same problem i went to las vegas on the 15 the car was like bumping n going to one side....they told me it was suspension
Old Nov 26, 2008 | 08:06 PM
hayaimoto's Avatar
I think its a common problem with these cars. My G wobbles from side to side at times on the freeway...anyone else experience this?
Old Nov 27, 2008 | 08:32 AM
jimmyc13's Avatar
WHAT!? Hellz no! Must be your suspension, how many miles are on it?
Old Nov 27, 2008 | 10:51 AM
DaveB's Avatar
It's a factor of the road surface, the particular tires, the suspension set up, and alignment specs on these cars. It is entirely normal. My 94 Z28 and modded Maxima would tramline as well. If you don't want tramlining, you'll have to:
1) move to a state with better roads, Florida or Cali are good choices
2) buy a car/SUV with less aggressive suspension settings and taller tires
3) live with it
Old Nov 27, 2008 | 02:38 PM
bigwilly's Avatar
If you are tramlining then it is most likely your tires. Wide, low profile, uni-directional tires with stiffer side walls exhibit this behavoir more. I get it when I have my summers on, I don't have the problem with my winters.
Old Nov 28, 2008 | 07:26 AM
jimmyc13's Avatar
No kidding. I have never heard of this. I ride on 245/40/19's...unidirectional (T1'R's) and have never experienced this
Old Nov 29, 2008 | 02:46 PM
mIKE's Avatar
T1R's are not very agressive tires.
Sticky tires are the ones that tramline worse.
Old Nov 29, 2008 | 07:03 PM
Mustang5L5's Avatar
My Mustang with 275's up front and 295's out back does this like crazy. When i put a stock set of wheels on it with "normal" tires. It stops. Low profile aggressive tires just do it. I've learned to live with it.
My G doesn't do it, and part of me doesn't want to change the wheels and tires because i like how it goes perfectly straight when i take my hand off the wheel.
Old Dec 4, 2008 | 05:57 PM
hayaimoto's Avatar
Thanks for all the words guys, but the car is riding on stock sized wheels and tires. Im going to put on my work wheels to check if its the actual tires that cause the problem or if it might be suspension related (shocks)
DaveB: I live in California and the roads here are not as nice as everyone thinks =X
The car's 100% stock btw
Old Dec 4, 2008 | 06:30 PM
az1anbeethoven's Avatar
it's the tires...i had that problem before with my previous set of tires...after I changed it, no more...and those were on the same road...
Old Dec 8, 2008 | 01:20 AM
DKatman's Avatar
Interesting to note. I have had this in a terrible way for several months in my former car, 2002 Pontiac Grand Prix GT on the 10 Freeway, from West LA to Downtown. Just got my G35 with Relatively Vanilla tires. I will see (when I take the Freeway, instead of the streets) if it is still here.
Dave
But it is enough to guess it is not a defect with your car.
Mry
Mar 3, 2023 01:03 AM
bTanz
Oct 15, 2015 02:31 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
Decimus141
Aug 13, 2015 08:42 AM
Detailed Image
Aug 10, 2015 02:29 PM
