Canada Serving Canada.
Anyone in GTA get fuel limit vent looked after by a dealer?
Old Apr 28, 2012 | 10:04 PM
akoustic's Avatar
I have classic Infiniti issue... the stupid problem with FLV. I can't put gas more than half tank at times...
I'll need to get this looked after following the TSB: ITB08-041a service bulletin. (http://www.infinitig37.com/TSB/1SC29.pdf)
Has anyone in the GTA area had this problem and have the dealer fix the issue? The only fear I have is the dealer mech not following the TSB correctly or do the job "half ****"... by reading the TSB in detail it will need extra attention...
Need your feedback! Thanks!
Old Apr 28, 2012 | 10:17 PM
Exceptional's Avatar
I have the same problem.
However, I found some pumps work better then others. There's one that stops pumping every $5, however, the one on the other side fills up almost all the way! :O lol
So try using different pumps.
If that doesn't work, theres a DIY thread on here on a fix. You might want to do that, but it looked too complicated for me.
Old Apr 30, 2012 | 02:38 PM
Bastone's Avatar
I have this issue too, as of recently.
TSBs are only covered if you're still under warranty, other than that, you'll have to pay large to have the dealership do it.
Old May 4, 2012 | 07:31 PM
strykez's Avatar
hey
next time you fill up and it does that turn the nozzle sideways and pump. should work
Old May 4, 2012 | 11:50 PM
I love it when it shows i have 1/4 tank left and 5 minutes later its 1/2 full lol.
Old May 9, 2012 | 08:52 PM
Imperial1's Avatar
I have that problem with my coupe as well, but not too often.. prob every 4-5 fillups or so. It's damn annoying when it does happen though.
yoyoyo8
Aug 12, 2015 03:04 AM
wylin
Lights
Jul 18, 2015 06:12 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
djreinx
Jul 13, 2015 05:04 PM
