Canada Serving Canada.
Best place to get clutch replaced
Old Aug 26, 2013 | 02:02 AM
Exceptional's Avatar
recently the clutch just gave out on my 03 coupe. well not yet, but it is slipping a lot when you try to gas it
im looking for a place that can fix it
also, any idea what a 'right' price it would be for this? oem or aftermarket whichever is cheaper but works the best/same
Old Aug 26, 2013 | 09:34 AM
redpearl99's Avatar
you can get an oem clutch for fairly cheap ($75). Just make sure your flywheel is good, it cant be resurfaced easily and is quite expensive.
Old Aug 27, 2013 | 02:01 AM
oh wow its only 75
how many hours of labour is it?
im honestly not sure if its just the clutch.
i just know whenever i try to accelerate suddenly or push down more than usual at once, the rpms jump up by like 500-1k rpm, then drop down and aceelerate
based off my findings that should be the clutch
Old Aug 27, 2013 | 02:25 PM
Hossmaxima's Avatar
If your doing the clutch, you should consider doing the flywheel as well depending on the condition, its already disassembled.
Old Aug 28, 2013 | 04:59 PM
ge35es's Avatar
if memory serves me correctly these clutche systems are hydraulic much like the brake system...
so old fluid.. or low fluid or an air bubble could affect the performance of the system
I'd check for leaks, replace the fluid, and bleed it properly before shelling out the big $ for a full replacement
jsimonk
Dec 22, 2023 03:49 PM
TurboEE
Jul 31, 2015 10:41 AM
socalg35x
Jul 28, 2015 10:42 AM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
