Help, Cylinder Block Heater
Hello,
I have a 2007 G35x (second gen sedan V36 with VQ35HR motor). It is a US spec car, it does not have the cylinder block heater that Canadian cars come with. I live in New England and I park outside. I am considering buying an engine block heater, but I don't know how involved installation is.
Has anyone installed one of these themselves? I couldn't find a DIY on the forum. I tried to find an installation procedure in the FSM, but I couldn't find it. I think I am looking at a US Manual and I don't think it is in there.
Any help is greatly appreciated.
-Fred
-Fred
wait.. how cold does it get where you are? I've started my car in -15*F weather and it started up just fine.. unless you have weeks of straight 0 degrees or below, I don't see the need of having a block heater.
http://www.usclimatedata.com/climate...tates/usct0094
My car has never failed to turn over, but I have heard that cold starts are rougher on the engine. I am interested in reducing wear and tear.
Also, after an overnight cold soak I have experienced acceleration stutter under low throttle. According to service bulletin ITB07-045 this could be due to a cold engine. The solution offered in the ITB is an ECU reflash. I am interested in addressing the root cause of the issue.
http://2007.infiniti.g35x.googlepages.com/ITB07-045.pdf
edit: wrong ITB#
I have no experience with this, but you might consider it.
http://www.canadiantire.ca/en/pdp/au...l#.VJIUyVpH0y4
GL
GL
BradMD_96
Oct 6, 2015 09:31 AM
