Hyper Ground
Originally Posted by Gordgee
Colin:
Oh crap. I almost forgot about you and your M! (Not really, but I've been so busy with both my jobs
). I have the measurements and ground points for your M. As soon as I get some instructions together, I'll have your M45 GroundingGear® Performance Series System ready for you if you're still interested.
Whenever you can get to it bro, and TNX.
Colin.
Originally Posted by G-Force
GordGee has an excellent product and instructions are great. Hardest part was getting the wires through the battery grommet, I would recommend using a utility knife to cut a small slot not drilled hole as instructed. It's almost impossible to drill a hole in rubber. Here are photos of the install.
) I drilled 2 holes with no problems and the install looks very clean and professional. The same technique worked when putting a hole in the wire grommet for the ECU ground. Very easy to do and a very clean install look and a perfect seal.
Originally Posted by G35 6MT
Use a sharp 3/8" drill bit and a some pressure and it goes through the rubber easily. Created a very clean hole that the grounding wire easily passed through with a little lube (your choice
) I drilled 2 holes with no problems and the install looks very clean and professional. The same technique worked when putting a hole in the wire grommet for the ECU ground. Very easy to do and a very clean install look and a perfect seal.I used to just recommend using a sharp utility knife in the instructions, but some were making the hole too large and it was difficult to seal which became more important with the ECU wire pass-through into the passenger compartment. The drill bit makes for a more consistent and controllable result.
