Canada Serving Canada.
springs, or 350z full setup in toronto?
Old Apr 11, 2006 | 12:07 PM
Mr.Igor's Avatar
where in toronto can i get cheap springs ??? or even better a 350z springs and shocks for my sedan.
i am also looking for good quality tint for cheap.
Old Apr 11, 2006 | 12:30 PM
Esoteric's Avatar
I searched hi and lo for a place to get them cheap in Toronto, but couldn't find anywhere, so I went to my350z.com. If you go to the classifieds, you'll find tons of them for sale.
Had them shipped in a few days, and I was ready to go. Of course, I haven't installed them yet, but based on all the feedback, I'm in for a treat!
Old Apr 11, 2006 | 12:40 PM
Mr.Igor's Avatar
customs!!! they rape you
Old Apr 11, 2006 | 01:16 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
If you check periodically, you should be able to find some from a Canadian member.
Old Apr 11, 2006 | 01:51 PM
jasonintoronto's Avatar
are 350z springs a good idea? aren't the spring rates very different considering that we have different wheelbases (thus engine location, weight balance is different?)?
Old Apr 11, 2006 | 02:09 PM
Mr.Igor's Avatar
thats what i thought, but if you look through the the board a lot of members done it. i would be cheaper then buying new aftermarket shocks and springs.
Old Apr 11, 2006 | 02:12 PM
InTgr8r's Avatar
No, spring rates are the same as the sedan's sport suspension.
('05s rear are slightly firmer)
Old Apr 11, 2006 | 02:41 PM
noodleman's Avatar
Ian, does that apply to the revised spring rates that 350z got? The 04.5+ springs rates are stiffer than the 03, regular 04 spring rates.
Old Apr 11, 2006 | 02:48 PM
InTgr8r's Avatar
The '05+ front are the same, the rear are slightly firmer.
I have the revised '05 & they're perfect!
(especially with D-Specs)
Old Apr 11, 2006 | 03:23 PM
noodleman's Avatar
Wait, we might be talking apples and oranges here...
The 350z 04.5+ springs have stiffer spring rates than the 03 and 04 350z's.
Are you talking about the 05+ G35 sedans?
Old Apr 11, 2006 | 03:26 PM
Esoteric's Avatar
True, if you're buying from a shop, but if another member in the states is sending you a 'gift' it can be quite painless actually.
Having said that, I've been lucky enough to find a few things from Canadian members out west, and even a couple locally.
I got hurt on stuff from shops, but stuff from other members came in just fine.
Old Apr 11, 2006 | 03:32 PM
InTgr8r's Avatar
oops my bad...
You're right '04.5 was when they changed....
To clarify I have '05 Z springs on my '04 sedan
Old Apr 11, 2006 | 03:33 PM
Mr.Igor's Avatar
now the question is do i need a new camber kit? or anything else replaced but the shocks and springs?
Now regarding the years of production, i have 2003.5 sedan. Which year 350z shocks and springs would workthe best for my case? 04-06? or what which years? What is D-Spec? I just got my g35 3 weeks ago.
Old Apr 11, 2006 | 03:38 PM
InTgr8r's Avatar
No camber kit required.
You will be at the same height as OEM 350Z,
which has the same upper control arm as we do.
Old Apr 11, 2006 | 05:24 PM
Mr.Igor's Avatar
Do i need the upper mounts also? or the stock ones are fine?
