BackSeat Question? Carputer Related
Old May 16, 2005 | 01:07 PM
gizsf's Avatar
New re-optimized Centrafuse out at the end of the month.....
Old May 16, 2005 | 01:09 PM
TwiBlue's Avatar
hmm I think a 90 should be fine, worst comes to worse, ill get a 120. Does anyone know how to ground the wire to the battery? If so is there a DIY for it? Or any instructions?
Old May 16, 2005 | 01:15 PM
gizsf's Avatar
Just ground it directly to the car. If it is in the trunk....there are many grounding points you can find on this forum...same as grounding any car stereo amps...just make sure to sand the paint off a little to get a good contact. Always use wire as thick or thicker than your power line and try to keep the ground wire within a few feet.
Old May 16, 2005 | 01:18 PM
gizsf's Avatar
TwiBlue....which area are you from? If your around the bay area....I can lend a hand.
Old May 16, 2005 | 01:34 PM
TwiBlue's Avatar
Thanks for the offer but im actually on the other side of the country, MD Ive never grounded a wire before or installed a stereo etc, This will be my first electrical mod.
Old May 16, 2005 | 04:25 PM
gizsf's Avatar
If you have'nt done any of that before...have a friend who has experience with car-audio, at least help you out. The last thing you want is a car-bq. Make sure that any wires with power are not going to rub against anything that could cause it to short(or cut) and re-seal any holes that you use to enter the inside of the car. Fuses on the positive sides are your best friends. The car itself negative(black or -) or ground, that is why your battery negative terminal under the hood attaches to the metal of the car. Theres a lot more to it than that.......seriously...have someone help you out as far as the wireing goes.
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
THMotorsports
Midwestern
Jul 22, 2015 10:27 AM
