My 2nd G35 Carputer Creation and Install
Old Jun 26, 2006 | 06:24 PM
gizsf's Avatar
This is the one I'm using. I havent had any problems with it....its rated at 3.0 amps if I remember right.
http://cgi.ebay.com/7-Port-USB-2-0-Hub-Powered-Aluminium-Stylish-Very-Small_W0QQitemZ130001518931QQihZ003QQcategoryZ96866QQrdZ1QQcmdZViewItem
Old Jun 27, 2006 | 03:26 PM
rcdash's Avatar
the hub makes a BIG difference. some are just sh!tty. the 7 port ones that come with 2.1 amp adapters (such as the one linked) don't make any sense to me. 500 ma * 7 = 3.5 amp draw.
I've had the best luck with the 4 port hubs (which also come with 2 amp power supplies - hmmmm), though the brand/chipset does indeed seem to affect reliability...
it's a trial and error proposition...
Old Jun 27, 2006 | 07:13 PM
gizsf's Avatar
I forgot to mention...I am not using all 7 ports. My gps goes directly to the pc, and all the others (5 or so) through the hub. The power supply I am using spits out 3amps on the (usb only) 5v rail so this is plenty for my needs and has worked fine so far.
Old Apr 18, 2007 | 11:46 PM
gizsf's Avatar
I got set back by a few knee surgeries, but now I'm back on it. It's almost done and here are a few pics of the progress.
Attached Thumbnails My 2nd G35 Carputer Creation and Install-img_0459.jpg   My 2nd G35 Carputer Creation and Install-img_0460.jpg   My 2nd G35 Carputer Creation and Install-img_0461.jpg   My 2nd G35 Carputer Creation and Install-img_0462.jpg   My 2nd G35 Carputer Creation and Install-img_0463.jpg
Old Apr 20, 2007 | 09:12 PM
caelric's Avatar
Heh! Your mess of wires looks *almost* as bad as my mess of wires!
Dave
Old Apr 29, 2007 | 10:23 PM
gizsf's Avatar
Dave
That's only the tip of the iceberg..theres plenty more already hidden.
Old Apr 29, 2007 | 10:33 PM
gizsf's Avatar
I got around to getting some pics of the setup. All the functions from the first pc are there so I didn't retake any of those. These are also with the other front end that I'm using now. I still have a few things that I plan to add on soon since I already have the parts here or on the way. I also hard wired my radar and put the mute switch for it into the center console since I had everything in pieces anyways. The backup camera is on its way and after that...bluetooth/mic for pc to phone and voice commands. Hope you guys like the work.
Attached Thumbnails My 2nd G35 Carputer Creation and Install-img_0471.jpg   My 2nd G35 Carputer Creation and Install-img_0468.jpg   My 2nd G35 Carputer Creation and Install-img_0476.jpg   My 2nd G35 Carputer Creation and Install-img_0467.jpg
Old Apr 29, 2007 | 11:24 PM
driftGT350's Avatar
crazy!
Old Apr 30, 2007 | 12:23 AM
blksnake's Avatar
Looks great!
Old May 2, 2007 | 01:25 AM
Gsmurf's Avatar
looks sick. you need to come to the east coast and help me do this to my car. I WANT A CARPC lol!!
Old May 2, 2007 | 01:30 AM
gizsf's Avatar
Thanks guys. If any of you do need help setting one up, I am always willing to donate my time to anyone who wants to do this themselves also. Feel free to ask any questions about this kind of stuff and I'll do my best to help you out.
Old May 2, 2007 | 01:39 AM
Rooz's Avatar
Very nicely done, I'd seena few in person, yours looks pretty clean. (Probably cleanest i'v seen)
Old May 17, 2007 | 03:47 PM
BXG35x's Avatar
have u had any heat issues since u put it in the upper glove box?
Old May 18, 2007 | 03:53 PM
gizsf's Avatar
Thanks for the kind words fellas.
No heat issue to date, even when doing a bunch of updates for hours running at almost full load for quite a while. I am using the stock cpu fan, and I put a small high volume fan over the power supply. Both are blowing onto the components and then there are 2 ports for the air to escape. Have to wait and see when the weather actually gets hot here in SF (which is rarely) and see if there will be any issues then. If there are any, I have a spare wisper fan and a small diameter tube duct that I can run then and it would be fine.
Old May 18, 2007 | 03:58 PM
  #30
vaughn6mt's Avatar
Is it me or is the screen crooked?
